That points out to back EMF or induction causing a spike in supply voltage, so you should check grounding, power supply, wiring as somehow that voltage generated by the spindle disconnecting or free-wheeling is getting back to the 7i92.crowloy wrote: ok. last issue I think. I can Fwd the spindle and Rev the spindle all day long as long as I don't hit stop. Once I hit stop, I have to reset the 7i92 controller before i can get a response of it.
