PathPilot Screen freezes after idle for an hour.
- Thank you received: 5334
23 Jul 2019 17:35 #140325
Replied by PCW on topic PathPilot Screen freezes after idle for an hour.
What CPU chip are you using? It may be too new for PathPilots OS
- Vmax549
- Thank you received: 28
23 Jul 2019 17:36 #140327
by Vmax549
Replied by Vmax549 on topic PathPilot Screen freezes after idle for an hour.
I have gone back to teh onboard port and it will not load PathPilot
"OpenGL not supported" AND there are NO linux Mint drivers avaiable.
Does anyone know how to install a driver from DISK/USB I have a driver that is known to work but have no idea on how to install it.
TP
23 Jul 2019 18:08 - 23 Jul 2019 18:36 #140336
I ask because the onboard video Intel should "just work",
but if you have a very recent CPU (newer than the OS)
you would expect these types of video problems
Last edit: 23 Jul 2019 18:36 by PCW.
- Thank you received: 7491
23 Jul 2019 18:12 #140338
Replied by tommylight on topic PathPilot Screen freezes after idle for an hour.
What type of file is it ? Deb, .sh, tar ?
- Vmax549
23 Jul 2019 19:02 #140341
by Vmax549
The CPU is INTEL. Teh video side is also INTEL HD
The driver file is a DEB file
23 Jul 2019 19:07 #140342
Right, but what is the complete Intel CPU model?
( there are 9 generations of I3s dating back to 2010 )
23 Jul 2019 19:16 #140343
If even that does not work, open a terminal and paste this:
sudo apt install gdebi
y
For the cpu type, open a terminal and type
lscpu
notice the number after I3
You can just double click on that and it should show the screen for gdebi package installer, if it does not, right click>open with>choose gdebi>ok.The driver file is a DEB file
y
lscpu
- Vmax549
23 Jul 2019 19:31 #140344
by Vmax549
operator@tormachpcnc:~$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 158
Stepping: 10
CPU MHz: 800.115
BogoMIPS: 7393.31
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 4096K
NUMA node0 CPU(s): 0-3
CPU(s): 4
Socket(s): 1
NUMA node(s): 1
CPU family: 6
Model: 158
Stepping: 10
CPU MHz: 800.115
BogoMIPS: 7393.31
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 4096K
- Vmax549
23 Jul 2019 19:37 #140345
by Vmax549
The label on teh box says Intel Pentium Gold G...54W/58W BX80684G5400
Maybe it is NOT i3 ??
TP
23 Jul 2019 19:43 #140347
That looks like i3- 7100 cpu.
There are two things wrong with your system, both wrong BIOS settings:
You have hyperthreading enabled, must be dissabled and your processor is set to run at 800 MHz ???
It should run much faster.
I do not know what Bios does your motherboard use, but do a search for it and see how to change that.
Time to create page: 0.247 seconds
