- Thank you received: 4153
smgvbest wrote: I've used JCLPCB, PCBWAY and others, JLCPCB has been my most reliable and quickest delivery so far.
I'm over on EEVBLOG also as SMGVBEST and currently repairing a E4407B Tracking Gen. Though its been on hold for some time
smgvbest wrote: Sent you a email just now.
Thank you for the assist
I've just designed a couple of boards and ended up just buying the prototype boards from JLPCB and a mate is going to solder them up for me. JLPCB only chooses parts from their library which was a stumbling block for assembly one board.
So when the time comes to get a few boards made, where is the best place to go? Being in Australia, China is the normal source.
rodw wrote: Thanks, I managed to source all of the components locally and the components were generally cheaper than the Chinese quotes. I bought a digital microscope which looks like it would be pretty handy and am wondering about buying a small oven. in the meantime my mate now has everything to do the job.
It has still cost a bit but I did not want to buy $2k-$3k worth of boards without knowing if they would work or not!
smgvbest wrote: that is a sad fact of board design. having to re-spin a new board because of some trace you missed or got wrong. kicking yourself for it because now it's so obvious and you missed it. sending off for a new board run then you do it again. don't ask me how I know :whistle:
Thats what I do like about JLCPCB and other quick turn around PCB shops. you can get the new board done, get a new prototype validate then place the large order
I use a standard inspection microscope with a .5x barlow on it to increase the working distance. its a tri-noc so a camera up top when I need one also.
