I have made some progress the last day's with up's and down's in C code.
Thanks, Rod, for your e-mail examples.
For example, i made 2 brand clean configurations. Started with zero code, just to be sure.
One without external offsets. This was hard to program. It's just not made
for thc function's. After spending a lot of time in that, i switched to external offset's. This was much easyer to write C code for.
The difficulty in the standard linuxcnc distibution is that making offset's and stay them in line is a little bit of hard to do with a few lines of code for a new C programmer. Maybe over a few years i will say, yes i missed something in that time, now it's easy. :laugh:
Today cutted a sample for my wife with the new C code. After tuning a few gui parameters, it cut's better then Mach3 windows.
But it's a long way to the top. At the picture my nozzle was damaged, so i am not satisfied about the holes.
I would like to make contact coming time with the Russian cnc forum that has made the Inkscape plugin.
My investegation is import a dxf right into the gremlin screen as g-code with inkscape only loaded as blockchain.
My C code language is improved a little bit, With compiling i get less errors, because you know how to use the language.
Here a example code that i used with succes, it's still basic in the eye of the C-coder,
The code is only related to the probe function :
component THC2 "Torch Height Control for stepper and servo machines, compatible with external offset branche";
description
Todo
author "Grotius CNC Machines";
license "GPLv2 or greater";
option singleton yes;
// Input Pins
pin in bit Enable "Enable component";
pin out bit Reset_offsets "Reset offsets to orginal condition when component is not enable";
pin in float Zpos_in "";
pin out float Zpos_out "";
pin in float Travelheight "Z axis travelheigt in";
pin in float Cutheight "Z axis cut height in";
pin out float Maxspeed "Z axis speed out 0 to 100, for info only";
pin out float ProbeSpeed "Z axis probing speed";
pin out float Speed "Z axis current speed, for info only";
pin in float Piercespeed "Z axis pierce speed in 0 to 100.";
pin in float Piercedelay "Z axis pierce delay time in seconds";
pin out bit Piercetime_reached "Piercetime reached";
pin in float Up_down_resolution "When Torch up, then correction 0.1mm or 1mm resolution";
pin in float Axis_z_eoffset "Connectod to external offsets z real time current z axis position input";
pin in float Pierceheight "the pierce height value in mm";
pin out float Offset "Z axis Offset command to external offsets, the z axis is moving to this offset when set, even in pause";
pin in bit Torch_on_in "Connected to spindle-cw";
pin in bit Probe_enable "Connected to user interface button";
pin out bit Probe_trigger "If probe is triggered this pin becomes high";
pin out bit Cutting_trigger "At cutheight and cutting";
pin in float Probe_search_limit "Connected to user interface input, z axis probe end limit. For example Z -10 = probing to max Z-10.";
pin in float Probe_switch_offset "Probe sensor switch correction value, positive z-value";
pin out float Zpos_probe "Z value when probe was triggered";
pin in bit Arc_ok_in "Parport connections in 12";
pin in bit Torch_up "Parport connections in 13";
pin in bit Torch_down "Parport connections in 11";
pin in bit Probe_in "Parport connections in 15";
pin out bit Torch_on_out "Parport connections out 17";
pin out bit Pause_machine "Connect to motion.feed-hold-inhibited";
pin out float Zpos_cmd_out ;
variable double time;
function _;
#include "rtapi_math.h"
#include "stdlib.h"
#include "stdio.h"
FUNCTION(_) {
Zpos_out = Zpos_in;
if(!Enable){
Reset_offsets = 1;
Offset = 0;
Probe_trigger = 0;
Torch_on_out = 0;
Piercetime_reached = 0;
time = 0;
Pause_machine = 0;
if(Enable){
if(!Torch_on_in){
Torch_on_out = 0;
Offset = Travelheight;
Cutting_trigger = 0;
if(Torch_on_out){time += fperiod;}
if(time >= Piercedelay){ Piercetime_reached = 1;}
if(!Torch_on_in){time = 0; Piercetime_reached = 0;}
Reset_offsets = 0;
if(Probe_enable){
if(!Torch_on_in){
Probe_trigger = 0;
Pause_machine = 0;
if(Torch_on_in && !Probe_in && !Probe_trigger){
Offset = Probe_search_limit;
Pause_machine = 1;
if(Torch_on_in && Probe_in){
Zpos_probe = Axis_z_eoffset;
Probe_trigger = 1;
Pause_machine = 1;
if(Torch_on_in && Probe_trigger){
Offset = Zpos_probe + Pierceheight + Probe_switch_offset;
Pause_machine = 1;
if(Torch_on_in && Probe_trigger && ((int)Offset == (int)Axis_z_eoffset) ){ // moving to pierceheight, if at height, ok.
Torch_on_out = 1;
Pause_machine = 1;
if(Torch_on_out && Piercetime_reached){
Offset = Zpos_probe + Cutheight + Probe_switch_offset;
Pause_machine = 1;
if(Torch_on_in && Piercetime_reached && ((int)Offset == (int)Axis_z_eoffset) ){ // add arc ok signal.
Cutting_trigger = 1;
Pause_machine = 0;
if(Torch_up && Torch_on_out && Cutting_trigger && (Axis_z_eoffset <= Travelheight) ){
Offset = Axis_z_eoffset + Up_down_resolution ;
Pause_machine = 0;
if(Torch_down && Torch_on_out && Cutting_trigger && (Axis_z_eoffset >= Probe_search_limit) ){
Offset = Axis_z_eoffset - Up_down_resolution ;
Pause_machine = 0;
if(!Torch_down && !Torch_up && Torch_on_out && Cutting_trigger){
Offset = Axis_z_eoffset;
Pause_machine = 0;
// Code Example Library :
// if(Simulate_arc_ok_in){Arc_ok_led = 1;} else {Arc_ok_led = 0;}
//time += fperiod;
//if(Torch_on_in){time += fperiod;}
//if(time >= Piercedelay){ Piercetime_reached = 1;}
//if(!Torch_on_in){time = 0; Piercetime_reached = 0;}
The C code example is only for using the Probe function. This was the most difficult function to make. So i started with a
working probe function in C. The normal code without probe i made and is much easer to write.
So we are at the good way. I need to save the linux screen parameters automaticly. Maybe someone has an idea?
Yes, A difficult item when coding:
If you want to go to zero, check zero, and current z axis height value is : 0.0025
You have a big problem if you are using float variables.
So at the moment i map the z axis value at zero or a certain point. I used an integer value wich is : 0 or 1 or 2.
This solves many issues. For example. Are we on pierce height? Are we on cutheight? If we almost get there the integer will say
okey it's true. But solving little axis feedback and command values differences are in C coded hard to make straight.
