New Plasma Build
- Thank you received: 4151
05 Aug 2018 13:05 #115636
Replied by rodw on topic New Plasma Build
05 Aug 2018 13:13 #115637
And my home made magnetic torch breakaway. MK II as the first idea failed.
Rounded dowels were machined using a ball turner on my manual lathe. Proximity sensor used as a sensor.
I think if I did it again, I'd be lazy and buy one of these snapncut.com/
- tecno
- Thank you received: 127
05 Aug 2018 14:07 #115639
by tecno
Replied by tecno on topic New Plasma Build
That looks good!
- islander261
- Thank you received: 216
06 Aug 2018 03:38 #115663
by islander261
Replied by islander261 on topic New Plasma Build
Sorry guys I'm a bit late to the party. My floating head has about .25" of mechanical travel. The micro switch isn't adjustable leaving me with .09" of offset.
Rod
Nice looking magnetic break away. Mine is modeled after seanp's on Plasmaspiders design and works very well, I have posted photos showing it on other topics. I have a mechanical switch and it is very sensitive, a PITA sometimes but it really does save the bacon when hitting a tip up. When the switch finally dies I will replace it with a small prox switch like the HT one uses.
Just a quick refresher I used three about 12mm ball bearings for the locating features ( the old three points define a plane and on an equal lateral triangle so the sesitivity is the same from all directions) and the magnet is out of a hard drive to hold the parts together. The only points of contact are the three locating bearings ( glued to one side of the assembly).
Rod
- bevins
- Thank you received: 338
07 Aug 2018 02:57 #115715
by bevins
Replied by bevins on topic New Plasma Build
Floating Z axis for plasma head.
14 Aug 2018 12:29 #116042
Replied by andypugh on topic New Plasma Build
Catching up...
An option for a floating Z might be leaf-spring suspension. A pair of leaves top and bottom should hold a torch in place repeatedly. No wear parts and nothing to get fouled by grit.
For extra fun you can strain-gauge the flexures as the sensing element.
This isn't entirely my idea, it's based on the Z-height adjusters of a set of machines I used to work on, used to set strikers sub-micron distances above chip wafers to mechanically test bonds .
I wonder if magnetic handbag clasps could be used for a break-away system? I bought some for a project and they do give the impression that they "want" to be used for this sort of task, if mounted in triples.
- Clive S
- Thank you received: 486
24 Jul 2019 17:33 #140441
by Clive S
John . I have just come across this do you have a link to the photo's of it. How are the ball bearings mounted?
Replied by Clive S on topic New Plasma Build
Rod
- islander261
24 Jul 2019 20:05 #140466
by islander261
The bearing balls are glued in with JB Weld on my version of this which is closer to Sean's Mk1 design.
www.plasmaspider.com/viewtopic.php?f=103...499&p=152510#p152510
www.plasmaspider.com/viewtopic.php?f=103...279&p=117983#p117983
24 Jul 2019 22:45 #140482
I had to find a reason to use the ball turner I made so I machined the end of a dowel (which is glued in cos, I got the tolerances wrong for a press fit....
- Clive S
25 Jul 2019 07:30 #140510
by Clive S
I have a small lathe Myford S7 this is the creature that got me in to linuxcnc so I should be able to make the dowel ends. If I can work out the code.
Time to create page: 0.359 seconds
