Snuggly's Plasma Build
7 years 11 months ago #121196 by snugglylovemuffin
Looks like I'll need to setup a postgui as you suggested. Would you mind helping me with that?
7 years 11 months ago - 7 years 11 months ago #121308 by snugglylovemuffin
Issue is solved; however I'm back to where I was last time I tried the TOMA setup:
THC.hal:157:Pin 'joint.3.motor-pos-cmd' was already linked to signal 'z-pos-cmd'
Not sure how to negotiate this particular hurdle.
Last edit: 7 years 11 months ago by snugglylovemuffin.
7 years 11 months ago #121310 by alan_3301
Replied by alan_3301 on topic Snuggly's Plasma Build
If you already have joint.3.motor-pos.cmd going to z-pos-cmd then change line 157 in THC.hal to read
net z-pos-cmd => mux2.5.in0 sum2.2.in1
7 years 11 months ago #121311 by snugglylovemuffin
I am just emulating the entire TOMA 7i77 file as much as possible. Running into a bunch of errors but I'm knocking a bunch of them out pretty rapidly by replicating the build. Might just try modifying his build.
7 years 11 months ago #121314 by snugglylovemuffin
I'm just shotgunning these files together and chasing down errors. We'll see where it gets me. Here's what I've got so far. Hope you all had a good Thanksgiving. I'll be thankful when the machine starts making me money ;)
7 years 11 months ago #121346 by tommylight
Replied by tommylight on topic Snuggly's Plasma Build
snugglylovemuffin wrote: I am just emulating the entire TOMA 7i77 file as much as possible. Running into a bunch of errors but I'm knocking a bunch of them out pretty rapidly by replicating the build. Might just try modifying his build.
If you have steppers, do not use the 7i77 version, it is much easier to do the stepper version to work for you.
The normal stepper version should just have the references to parallel port changed to the 7i96 pins and signals.
The following user(s) said Thank You: snugglylovemuffin
Time to create page: 0.131 seconds
