Snuggly's Plasma Build
7 years 11 months ago #120904 by snugglylovemuffin
I've modified this file, and in searching for the associated custom postgui, I opened up all these files in notepad++ and these HAL files are effectively blank.
7 years 11 months ago #120919 by rodw
Replied by rodw on topic Snuggly's Plasma Build
I think this is a case of following more than one prophet. You can safely ignore what Andy hs said.
If you look in your ini file your POST_GUI file is defined as being THC_7i92_7i77_vcp.hal (Remember everything in Linuxcnc is configurable)
# A file to hook pyvcp to hal signals POSTGUI_HALFILE = THC_7i92_7i77_vcp.hal
So now lets focus on the error you reported. It said that there was an error on this line in THC_7i92_7i77_vcp.hal
net CHLThreshold pyvcp.Scale-CHLThreshold-f => scale.0.in
I had a look in your THC_7i92_7i77_vcp.xml file and I think all you will have to do is to change this line to refer to a pin that does exist. eg.
net CHLThreshold pyvcp.Scale-CHLThreshold => scale.0.in
7 years 11 months ago #121168 by snugglylovemuffin
If you're suggestion was to remove the -f from threshold-f, this just threw the same error as before, sans the -f. I suspect, however, that this wasn't what you had in mind. I understand the concept of "wiring" in the context of linuxcnc, however I'm not rightly familiar with the particulars. I'll snag my entire file and post it up here shortly.
7 years 11 months ago #121172 by rodw
Comment out the problem line so your system loads and then use Halshow (which is available from the GUI in Axis and Gmocappy) and explore the pins being exported by pyvcp. If you can't see any, revert to Andy's advice as it might be a post_gui thing.
Your error has told you a pin is missing, so you need to look at what pins exist. sometimes its a simple typo which I thought it was as in the XML the pin ending in -f did not exist.
The following user(s) said Thank You: snugglylovemuffin
7 years 11 months ago #121175 by snugglylovemuffin
Fantastic, will do!
7 years 11 months ago #121188 by snugglylovemuffin
So, postgui then?
Time to create page: 0.079 seconds
