Snuggly's Plasma Build
7 years 11 months ago #121512 by rodw
Replied by rodw on topic Snuggly's Plasma Build
Hmm, Andy, I wonder if with the benefit of hindsight if
motion.spindle-forward
was retained and received the same value as
motion.spindle.0.forward
That would solve a lot of conversion problems when people move a single spindle machine config to master. (How many would have multiple spindles right now anyway ?)
The following user(s) said Thank You: snugglylovemuffin
7 years 11 months ago #121517 by tommylight
Replied by tommylight on topic Snuggly's Plasma Build
alan_3301 wrote: Break your system and configuration down into manageable chunks that can be solved independently and logically. Get your motion stuff working and error free, archive your files for reference. Then make changes to try and get THC, or whatever other parts need work.
That is how it should be done, everything needs a priority list or order of things.
The following user(s) said Thank You: phillc54, snugglylovemuffin
7 years 11 months ago #121522 by andypugh
Replied by andypugh on topic Snuggly's Plasma Build
rodw wrote: Hmm, Andy, I wonder if with the benefit of hindsight if
The conversion script will convert configs that it is presented with, but doesn't get the opportunity when folk hand-edit to the old pin names.
The following user(s) said Thank You: rodw, snugglylovemuffin
7 years 11 months ago - 7 years 11 months ago #121556 by snugglylovemuffin
OMFG YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!
Okay, probably too early to start rejoicing, however linuxcnc booted up w/out error!
Thank you gentlemen. I had to change the stepgen (in THC.hal) over to the hm2_7i96... etc. and completely delete the "EMBED_TAB_COMMAND" to shirk the gladevcp errors.
Here is the current working file set, now forever on the internet for posterity (and my sanity) sake!
Last edit: 7 years 11 months ago by snugglylovemuffin.
7 years 11 months ago #121557 by Grotius
Replied by Grotius on topic Snuggly's Plasma Build
What is this?
Located in your plasma.hal :
setp hm2_7i96.0.dpll.01.timer-us -50
It looks like a timer with a negative value of -50 nano seconds?
Watchdog is 5 million nano second's?
Okey i understand stepgen control type = 1. :woohoo:
Nice you have no error's moving around. Keep up the good work !!
Next item would be to connect your z axis. Read about Tom's stepper solution for z axis.
7 years 11 months ago #121558 by snugglylovemuffin
My NC float switch is presenting a bit of a problem, I can't put it as in-not without linuxcnc error "pin doesn't exist".
I'll change it to NO for now, see if it has any problems. A potential fix is welcome however.
