Another plasma component...
7 years 5 months ago - 7 years 5 months ago #132796 by phillc54
Some more tool handling questions to show off my inexperience with plasma.
Up to now I have been thinking a tool change was only to change cut parameters.
I now think that sometimes it is required to actually change a nozzle as well as parameters.
IF TRUE:
- how do you guys do a nozzle change now? (the manual toolchange popup?)
- we need to be able to differentiate between a simple parameter change and a more complex nozzle and parameters change.
- we would need some sort of nozzle identification in the plasmac_tool_table, I had thought of Amps but then there a different nozzle types with the same current rating.
- how many different nozzle types per user would we need to account for?
- is there something standard in CAM tool tables that we could pick out?
- am I trying to do too much?
- life got harder...:(
IF FALSE:
- life is good...:)
I have got a prototype file converter working for you SheetCam users to copy SheetCam tool tables to plasmac format.
Does SheetCam always keep their tool table values as metric format?
If anyone has different format tool tables then I would be happy to have a crack at a converter after (if) we get tool handling sorted.
Cheers, Phill.
Sorry for the string of posts, the brain is a tad slow today...
Last edit: 7 years 5 months ago by phillc54.
7 years 5 months ago #132799 by islander261
Replied by islander261 on topic Another plasma component...
Phill
Just got home from the seasons first market on the mainland. I have updated my Plasmac config to your latest release and will test in the morning.
The SheetCam tool table I sent you actually sorts the tools by material, thickness and cutting current (nozzle size), that is one reason there are so many entries. People wanting to use this in a job shop setting will want every combination called out like the file I posted. I use one nozzle size almost exclusively and rarely use another. After doing this for 9 years now I still have my original packages of the higher current nozzles I bought when I started. Needless to say I have never heard of anyone changing the nozzle sizes between cuts on a work piece but I could be wrong ( a M6 and a manual tool change will still handle this).
Thanks again for all the hard work. The Plasmac branch works far better than anything else I have used. I may seem picky but really all I am doing is trying to push the (your) branch to be the best available solution for plasma cutting.
I actually found changing over to the Plasmac branch pretty easy. Of course I was starting from a working LinuxCNC driven plasma cutter. Including macro buttons for a test probe (check the actual physical height of a probe) and tests cuts of say 150mm (6") or so on each axis will be a big help to newbies, they may not know it but those are the first two things you need to do before cutting an actual part file.
7 years 5 months ago #132808 by phillc54
I am guessing that some regular nozzles and some fine cut nozzles have the same amperage. I also assume that there are more than these two types. To do a real tool change there would need to be a way of distinguishing between them.
I would be extremely happy if that is the case.
Unfortunately the work I have done on tool handling stops this working as normal (it has a remapped T word) but with individual nozzle assignment I could [strike]probably[/strike] possibly figure out a way to do it.
No, not at all, you need to be as I know nothing about cutting. I would love to achieve that result as well.
If you think any of your macros or modifications should be included I would be happy to put them in.
Cheers, Phill.
7 years 5 months ago - 7 years 5 months ago #132813 by phillc54
I have pushed an update for tool handling.
This ONLY applies to the Gmoccapy config and does not affect the plasmac component.
There are quite number of changes as listed below.
The standard LinuxCNC tool table is bypassed and a plasmac specific tool table is used. The tool table name is derived from [EMC]MACHINE in the in file, so a machine named METRIC_PLASMAC would have a tool table named metric_plasmac_tool.tbl. This file could be created by renaming your existing .mat file and modifying to suit.
The additional parameters are:
TOOL_NUMBER_ - this is now the section header rather than material name
NAME - this is the old header without []
KERF_WIDTH - this is passed to the #<kerf_width> parameter for cutter compensation
THC - this enables/disables THC on a per tool basis. 0 = disable, 1 = enable
All other parameters are as they were.
Tool numbers do not need to be consecutive nor do they need to be in numerical order. The maximum allowed tool number is 99999 as I believe this is the largest LinuxCNC will accept.
Tool handling is done by remapping the T word, so a M6 Tn will load the parameters associated with tool number n.
So if you don't want to use this feature then you can comment out:
REMAP = T prolog=plasmac_tool_prolog ngc=plasmac_tool epilog=plasmac_tool_epilog
in the in file.
When a tool is changed it only changes the cut parameter, LinuxCNC knows nothing of the tool or its offsets.
To use cutter compensation you will need to use G41.1, G42.1 and G40 with the new global parameter #<kerf_width> like so:
G41.1 D#<kerf_width> for left of programmed path G42.1 D#<kerf_width> for right of programmed path G40 to turn compensation off
Tools can be selected manually with the Tool number spin button but this does not load the new #<kerf_width> value, to do this you need to do a M6 Tn via MDI.
The supplied metric and imperial *_plasmac_tool.tbl files are not meant for cutting, they were just use for testing as are the metric and imperial *_tool_change.ngc files in the nc_files/plasmac directory.
I hope I haven't forgotten anything or broken too much.
Cheers, Phill.
File changes:
Warning: Spoiler!
7 years 5 months ago - 7 years 5 months ago #132815 by rodw
Phill, I don't think you need to worry about tracking nozzles. On my machine, they go hand in hand with the amperage chosen. eg 2mm 40 amps = 40 amp nozzle, 2 mm 60 amps = 60 amp nozzle. I have seen some posts that put some comments in the code to remind the user. I guess they use a pause or something.
You'll be please about that as I have about 7 tips I can use.
If I'm lazy, I can avoid changing out a nozzle by changing the selected material at a different amperage.
I did think about scanning the cut charts page diagrams of the consumables that show the part numbers and including a link to the image in the materials file. But all 40 amps mild steel would display the one image regardless of thickness. If there was an image included in a cut chart entry, you could unhide a button and display the image in a popup so you knew what parts you had to install.
Last edit: 7 years 5 months ago by rodw.
7 years 5 months ago #132816 by phillc54
I forgot to mention:
There is weird behaviour in Gmoccapy with the F word display. It seems that it displays the FeedRate for the segment after the one that is cutting. If you display velocity that is correct.
There is a python program named toolverter.py in the Gmoccapy folder. That will convert tools from SheetCam to plasmac. It only converts ones known as Plasmatools.
Cheers, Phill.
Time to create page: 0.200 seconds
