Another plasma component...
6 years 5 months ago - 6 years 5 months ago #168616 by phillc54
LinuxCNC changed the spindle on/off commands so where you have M5 you need to change it to either M5 $2 or M5 $-1
linuxcnc.org/docs/2.8/html/gcode/m-code.html#mcode:m3-m4-m5
Last edit: 6 years 5 months ago by phillc54.
The following user(s) said Thank You: Franklin
4 years 8 months ago #234211 by Aldenflorio
Replied by Aldenflorio on topic Another plasma component...
Okay, so with a plasma table that uses the mesa7i76 and the thcad10 which do I use? I have a floating head with a switch
4 years 8 months ago #234273 by Aldenflorio
Sorry all of these comments confuse me a lot
4 years 8 months ago #234300 by phillc54
I don't understand the question.
4 years 8 months ago #234301 by Aldenflorio
Which configuration do I use? For my last build I had the proma150 thc to which I used plasmac to set it up. Do I still instal plasmac and just configure it to the THCAD-10? Or are all these files outdated?
4 years 8 months ago #234303 by phillc54
You should be able to modify an existing config by using the configurator in "Reconfigure" mode.
linuxcnc.org/docs/2.8/html/plasma/plasma...e.html#modify-config
Of course make a backup of your config beforehand.
Time to create page: 3.705 seconds
