Another plasma component...
6 years 8 months ago #156731 by edgemir
Replied by edgemir on topic Another plasma component...
In fact, the stable configuration is executed in the same machine and the continuous movement works normally, but if I execute the version with plasmac the joggin no longer works.
This is a machine where I have already installed the proma compact 150 UP / DOWN THC, I have not tested it with a code and see if it works and cut, tomorrow I will do that test and I will tell you what happens.
6 years 8 months ago #156732 by phillc54
Thanks, I will build a VM with the Wheezy ISO and do some testing.
6 years 8 months ago #156736 by phillc54
One thing that you can try, in the [DISPLAY] section of the ini file, change:
CYCLE_TIME = 0.1
to:
CYCLE_TIME = 0.15
6 years 8 months ago #156744 by phillc54
I built a new VM and created a new config, then I created a config using your complete ini file and I still cannot see this issue.
Does jog work correctly before homing?
Attached is a sim hal file.
Could you run some tests using that instead of tci2thc.hal and see if there is any difference.
You may need to invert the sign of HOME_SEARCH_VEL and HOME_LATCH_VEL for[JOINT_0] and/or [JOINT_1] in your ini file for homing to work correctly.
6 years 8 months ago #156753 by Backerman
Replied by Backerman on topic Another plasma component...
Hi Phill, I have the same problem with continuous jog with Axis in sim config and on a working machine! Gmoccapy works!
My System is Debian 9 PREEMPT_RT with Linuxcnc 2.9, Buildbot!
Everything else works!
Thanks for the great work Phill!
File Name: plasmaaxis...2-08.hal
File Size:3 KB
File Name: plasmaaxis...2-08.ini
File Size:7 KB
File Name: terminal_testaxis.txt
File Size:4 KB
File Name: terminal_w...axis.txt
File Size:3 KB
6 years 8 months ago #156784 by phillc54
Backerman wrote: Hi Phill, I have the same problem with continuous jog with Axis in sim config and on a working machine! Gmoccapy works!
Thanks for those error messages, they seem to indicate a problem within Axis itself.
I don't know what has changed (if anything) and I don't know why I don't see the issue.
Looks like a bit of testing this week...
Time to create page: 0.630 seconds
