- Thank you received: 2100
Another plasma component...
- phillc54
7 years 4 days ago #148934
by phillc54
If you mean for THC in the Config Panel then P=10, I=0 and D=0 seems to work quite well.grijalvap wrote: Hi, I have some troubles to tune the PID loop basically I have a big steady-state error, I know every system is different, but do you have some guide or initial numbers?
thanks
- phillc54
7 years 4 days ago #148937
by phillc54
Could you post your .ini and .hal files plus any error messages you get.KRAD_AT wrote: Hello Guys!
Today I made a new Config and upgraded to plasmac.
Most of all seem to work perfect.
One thing I recognizes is that continuous jogging does not work. Jogging in increments works fine.
The same thing as user sevaz saw in the post below.
Is there a solution already?
- grijalvap
- Thank you received: 63
7 years 4 days ago - 7 years 4 days ago #148943
by grijalvap
Replied by grijalvap on topic Another plasma component...
Thanks i read an old notes un muy notebook ando ir si working now.
Last edit: 7 years 4 days ago by grijalvap.
The following user(s) said Thank You: phillc54, Clive S, rodw
- KRAD-AT
7 years 4 days ago #148978
by KRAD-AT
Replied by KRAD-AT on topic Another plasma component...
Hey Phil!
Thank you for your hard work on this project! You are great!
I attached my complete Config.
Cheers Martin
Cheers Martin
- phillc54
7 years 3 days ago #149020
by phillc54
Could you post the error message you are getting, the config works here as a sim.
- KRAD-AT
7 years 3 days ago #149028
by KRAD-AT
Unfaithfully there is no error message.
All I see is that jogging in increments (i.e 5mm) works, continuous doesn't.
Sorry I can't tell you more.
Time to create page: 0.370 seconds
