- Thank you received: 2100
Another plasma component...
- thefabricator03
- Visitor
7 years 1 month ago #146687
by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
Thats a tidy little table Phill,
I was going to go with a compressed air water height on mine but I changed my mind after making the first tank as I was worried that pressurizing a large steel tank could kill someone if any of the safety valves failed. I ended up with a 1000 l/m pump instead.
But on a smaller table it makes sense to use air pressure.
Is the table on castor wheels?
- phillc54
7 years 1 month ago #146690
by phillc54
Yes, it is on castors.
The pressure for the water is only 1.5 - 2 bar.
- thefabricator03
- Visitor
7 years 1 month ago #146691
by thefabricator03
My problem was I did not consider the safety factor of having a untested pressure vessel used in a workplace. Getting a tank 3000x1500x300mm tested is not cheap.
And a small amount of pressure over such a large area can cause problems. Especially if it were to pressurize up to our shop air pressure of 110 PSI.
But for a hobby machine is makes perfect sense. Especially when your the only one using it and you know what your doing.
- phillc54
7 years 1 month ago #146694
by phillc54
I will be the only one using it but I'm not sure that I know what I'm doing.
When I get the water to the correct level I unplug the air to be safe.
I can understand your concerns.But for a hobby machine is makes perfect sense. Especially when your the only one using it and you know what your doing.
- thefabricator03
- Visitor
7 years 1 month ago - 7 years 1 month ago #146696
by thefabricator03
What was me when I first started using my machine. I had never use any other CNC machine before apart from my robots. When I first started cutting I did not have any cut settings fully sorted and I started cutting a 20mm plate for a job. I think I only got about 3 good parts out of that 3000x1500x20 sheet. A very expensive learning curve. Looking back I would of done things differently but I learnt a hell of a lot.
Last edit: 7 years 1 month ago by thefabricator03.
- Thank you received: 4153
7 years 1 month ago #146704
Looks good Phill. I had a setback with my watertable as it had a leaking weld. I got as far as putting the tray in the back of the ute but had no time today to go and get the boys to reweld it (after all, I paid them to do it).
I've kinda half been looking for a tank of some kind but it needs to hold around 125 litres minimum.
Time to create page: 0.701 seconds
