Another plasma component...
7 years 1 month ago #144804 by Franklin
Replied by Franklin on topic Another plasma component...
I using a real config and it works fine except this function
I changed Torch On Time from 50 to 500 and nothing.
Earlier I used M10 file for turn Torch through the M64 / M65
But yesterday I wanted to try the built-in function and it didn’t work out.
7 years 1 month ago #144806 by Franklin
I meant that Torch On Time works, but the plasmaс repeats attempts in one place
7 years 1 month ago #144807 by Franklin
Today I’ll try to play with center mark again and take a video of how this happens
7 years 1 month ago #144810 by phillc54
I cannot get it to behave that way.
When you post the video, could you post all your .ini file, all your .hal files and all your .cfg files.
Attached is a file I test with.
7 years 1 month ago #144814 by Franklin
I understood why this is happening
in the line "g1 x0.000001", I removed a few zeros, I didn’t think that this would affect anything!
Now I repeated your example exactly and everything works as it should. Sorry this is my carelessness.
Thank you for your responsiveness and for all your work.
7 years 1 month ago #144815 by phillc54
Well I wouldn't have thought it would make a difference as well.
I'll have a look tomorrow.
The following user(s) said Thank You: Franklin
Time to create page: 0.259 seconds
