Another plasma component...
7 years 1 month ago #144751 by phillc54
Could you post the GCode file.
7 years 1 month ago #144797 by Franklin
Replied by Franklin on topic Another plasma component...
I used the sample GCode from the documentation
Warning: Spoiler!
And tried other GCodes, the result is the same.
How should this function work, the plasmac should wait for the arcOK?
It seems like the plasmac does not see the signal of the arcOK and repeats attempts many times.
7 years 1 month ago - 7 years 1 month ago #144798 by phillc54
Have you enabled multi spindle in your <machine>_connections.hal?
EDIT: Does the Arc OK led on the Monitor Panel light?
What GUI are you using?
Last edit: 7 years 1 month ago by phillc54.
7 years 1 month ago #144800 by Franklin
Yes I enabled multi spindle and changed the number of spindles to 3 in the ini file.
I use Axis GUI.
7 years 1 month ago #144801 by Franklin
And Arc OK led light on the Monitor Panel and on HAL Show too
7 years 1 month ago #144802 by phillc54
Are you using a sim or a real config?
What value do you have for Torch On Time in the Config Panel?
Acually it doesn't wait for Arc OK, it uses the above time.
Time to create page: 1.028 seconds
