- Thank you received: 2100
Another plasma component...
- phillc54
Looks like I won't be bored tomorrow.
Edit: is that a PlasmaC update or new config.
- Thank you received: 4153
tommylight wrote: Just updated to build 498 of 2.9 and got infinite loops !
Metric PlasmaC sim
Uspace
Mint 19.1
Linux acer 4.16.12-rt5-kona-rt #1 SMP PREEMPT RT Fri Jun 8 10:39:47 JST 2018 x86_64 GNU/Linux
Guess yesterdays commit has not gone through yet.
Report attached, pin 'spindle.1.on' does not exist.
Tommy. for now, just comment out the line in plasmac.hal that refers to spindle.1 and you should be good. There are some earlier posts here of mine today where I did fix this issue. There is very poor documentation of multispindle support in my view... You need to update your ini file and also update the loadrt motmod line in hal to load the spindle count or it is not pretty as you found out!
- phillc54
- Thank you received: 7491
Sim, included with Linuxcnc, same thing on the imperial version.phillc54 wrote: Damn, I thought I fixed that...
Bored ? come have a look at my workshop, got messed up badly last night from over 1 hour of relentless hailstorm, pushed in the polycarbonate windows and even got to the insides of the Mazak control panel, had 10cm of water all over the workshop, still assessing the damage, but first estimates over 7000 euros. Also got in the second floor of the house in one of the bedrooms like a bloody tap was opened. Add another K there.
Still had hail all over today till 1 PM in the garden and on the sides of the roads, and it is summer !
Back to cleaning.
- phillc54
Sounds like my day is going to be much easier than yours Tom.
I am good, just had to report that so others do not have the issue, i am not using it yet, working at a factory some 25 or 30KM away and driving daily, have to solve a lot of mistakes made with the moulds and fittings, adjust the blow moulding machine with the right temperatures for the preform, find workers, start 24h production with all the logistics involved, etc.rodw wrote: Tommy. for now, just comment out the line in plasmac.hal that refers to spindle.1 and you should be good. There are some earlier posts here of mine today where I did fix this issue. There is very poor documentation of multispindle support in my view... You need to update your ini file and also update the loadrt motmod line in hal to load the spindle count or it is not pretty as you found out!
Need to find someone to do the metal framing and tables for 5 plasma machines so i can start assembling them somewhere as i got no space in the workshop, etc, etc.
Need 80 hour days !
