Another plasma component...
- phillc54
- Thank you received: 2100
25 Aug 2019 13:01 #143143
by phillc54
If you run Configurator in upgrade mode it edits the machine Hal file and the ini file to create the pin.
The following user(s) said Thank You: sevaz
- sevaz
- Thank you received: 5
25 Aug 2019 18:29 - 25 Aug 2019 18:42 #143158
by sevaz
Replied by sevaz on topic Another plasma component...
I compiled rip version from gitgub, but it is still incapable of using continues jogging.
Last edit: 25 Aug 2019 18:42 by sevaz.
- Thank you received: 7488
25 Aug 2019 19:01 #143160
Replied by tommylight on topic Another plasma component...
What are you min_limit and max_limit in the ini file of each axis/joint ?
- sevaz
25 Aug 2019 19:45 #143165
by sevaz
It doesn't work even on the test setup(sim) that comes with the plasmac. So continues jogging doesn't work but incremental jogging works just fine.
25 Aug 2019 19:54 #143167
Are you using a wireless keyboard ?
- sevaz
25 Aug 2019 20:01 #143168
by sevaz
No, im using a wired keyboard. When i start just a normal axis without plasmac addons it works fine.
25 Aug 2019 20:08 #143169
I have not tested new versions of PlasmaC for the last month, so i do not know what could be causing that.
You should really check what are the min_limit and max_limit for each axis in the ini file.
- sevaz
25 Aug 2019 20:13 - 25 Aug 2019 20:45 #143171
by sevaz
Maybe i updated too early, so has caught some bugs. So i just deleted plasmac_axis.py and everything started to work like it should. But of course i lost all cool axis tweaks.
Last edit: 25 Aug 2019 20:45 by sevaz.
- Thank you received: 4150
25 Aug 2019 21:38 #143172
It didn't a few days ago when I ran the configurator. (after the 18th August update)
- phillc54
25 Aug 2019 23:37 #143175
by phillc54
That was fixed a couple of days later.
I'll have a look at a custom hal file somewhere
Yeah, I knowIt didn't a few days ago when I ran the configurator. (after the 18th August update)
Time to create page: 1.797 seconds
