Another plasma component...
- phillc54
- Thank you received: 2100
15 Feb 2020 22:28 - 15 Feb 2020 23:20 #157493
by phillc54
Does this happen for all axes?
Is it when touching off to Zero or to a specific value or both?
What locale do you use?
It is something to do with locales, I can duplicate it here.
Last edit: 15 Feb 2020 23:20 by phillc54.
- phillc54
16 Feb 2020 01:30 #157502
by phillc54
OK, this is a combination of a couple of errors.
- I didn't allow locale translation for a couple of buttons
- There was an error in the recent German translation updates
The following user(s) said Thank You: Backerman
- Franklin
- Thank you received: 19
22 May 2020 13:50 #168579
by Franklin
Replied by Franklin on topic Another plasma component...
Hi, I have not updated the plasmac for a long time, and now after update the spotting does not work , plasmaŃ repeats attempts in one place and does not move to the next position.
There was already such error, I wrote about it on page 171 .
Before updating this worked fine.
Can you try my file on your machine?
Thanks.
Thanks.
- Uthayne
- Thank you received: 49
22 May 2020 14:53 #168581
by Uthayne
Replied by Uthayne on topic Another plasma component...
I had this same issue and it was fixed for me by using the Rev E plasmac sheetcam pp
- phillc54
22 May 2020 23:59 - 22 May 2020 23:59 #168616
by phillc54
LinuxCNC changed the spindle on/off commands so where you have M5 you need to change it to either M5 $2 or M5 $-1
linuxcnc.org/docs/2.8/html/gcode/m-code.html#mcode:m3-m4-m5
Last edit: 22 May 2020 23:59 by phillc54.
The following user(s) said Thank You: Franklin
- Aldenflorio
- Thank you received: 15
07 Feb 2022 02:08 #234211
by Aldenflorio
Replied by Aldenflorio on topic Another plasma component...
Okay, so with a plasma table that uses the mesa7i76 and the thcad10 which do I use? I have a floating head with a switch
- Aldenflorio
07 Feb 2022 18:58 #234273
by Aldenflorio
Sorry all of these comments confuse me a lot
- phillc54
07 Feb 2022 22:30 #234300
by phillc54
I don't understand the question.Okay, so with a plasma table that uses the mesa7i76 and the thcad10 which do I use? I have a floating head with a switch
- Aldenflorio
07 Feb 2022 22:34 #234301
by Aldenflorio
Which configuration do I use? For my last build I had the proma150 thc to which I used plasmac to set it up. Do I still instal plasmac and just configure it to the THCAD-10? Or are all these files outdated?
- phillc54
07 Feb 2022 22:50 #234303
by phillc54
You should be able to modify an existing config by using the configurator in "Reconfigure" mode.
linuxcnc.org/docs/2.8/html/plasma/plasma...e.html#modify-config
Of course make a backup of your config beforehand.
Time to create page: 0.188 seconds
