Another plasma component...
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Sep 2019 09:24 - 11 Sep 2019 09:25 #144798 by phillc54
Have you enabled multi spindle in your <machine>_connections.hal?
EDIT: Does the Arc OK led on the Monitor Panel light?
What GUI are you using?
Last edit: 11 Sep 2019 09:25 by phillc54.
11 Sep 2019 09:38 #144800 by Franklin
Replied by Franklin on topic Another plasma component...
Yes I enabled multi spindle and changed the number of spindles to 3 in the ini file.
I use Axis GUI.
11 Sep 2019 09:42 #144801 by Franklin
And Arc OK led light on the Monitor Panel and on HAL Show too
  • phillc54
  • Platinum Member
  • Platinum Member
11 Sep 2019 09:45 #144802 by phillc54
Are you using a sim or a real config?
What value do you have for Torch On Time in the Config Panel?
Acually it doesn't wait for Arc OK, it uses the above time.
11 Sep 2019 10:04 #144804 by Franklin
I using a real config and it works fine except this function
I changed Torch On Time from 50 to 500 and nothing.
Earlier I used M10 file for turn Torch through the M64 / M65
But yesterday I wanted to try the built-in function and it didn’t work out.
11 Sep 2019 10:07 #144806 by Franklin
I meant that Torch On Time works, but the plasmaс repeats attempts in one place
11 Sep 2019 10:11 #144807 by Franklin
Today I’ll try to play with center mark again and take a video of how this happens
  • phillc54
  • Platinum Member
  • Platinum Member
11 Sep 2019 11:02 #144810 by phillc54
I cannot get it to behave that way.
When you post the video, could you post all your .ini file, all your .hal files and all your .cfg files.
Attached is a file I test with.
11 Sep 2019 12:03 #144814 by Franklin
I understood why this is happening
in the line "g1 x0.000001", I removed a few zeros, I didn’t think that this would affect anything!
Now I repeated your example exactly and everything works as it should. Sorry this is my carelessness.
Thank you for your responsiveness and for all your work.
  • phillc54
  • Platinum Member
  • Platinum Member
11 Sep 2019 12:17 #144815 by phillc54
Well I wouldn't have thought it would make a difference as well.
I'll have a look tomorrow.
The following user(s) said Thank You: Franklin
Time to create page: 0.205 seconds
