Another plasma component...
- phillc54
- Thank you received: 2100
Yes, it probes down at Probe Speed then after sensing the material it moves up at 0.001mm (0.00004") per period until contact is lost.Does Plasmac probe up again until the ohmic circuit breaks again to set surface height? I assumed it would do.
The debounce delay in the connections.hal will have a minor impact on height, around 0.001mm (0.00004") increase per unit.
- phillc54
You may haven an issue with that as I made the assumption that if someone was using a separate probe next to the torch then it would be below the torch so I restricted to values here to negative numbers. If you need positive numbers then you can change line 21 in plasmac_config.py from:but now I see there is an ohmic offset so I might play with that to get closer onto correct height
self.builder.get_object('ohmic-probe-offset-adj').configure(0,-25,0,0.01,0,0) self.builder.get_object('ohmic-probe-offset-adj').configure(0,-25,25,0.01,0,0)Please Log in or Create an account to join the conversation.
- Thank you received: 4150
to:self.builder.get_object('ohmic-probe-offset-adj').configure(0,-25,0,0.01,0,0)I can change it permanently if required.self.builder.get_object('ohmic-probe-offset-adj').configure(0,-25,25,0.01,0,0)
Phill, thanks, I'll see how I go. If its high, the adjustment should be negative then? You'd think it would be spot on the way you do it.
- Dee436
- Thank you received: 13
When void sense and the anti dive are on the thc seems not to move at all, so I guess I have those variables set to high which should be fairly easy to adjust. When I deselect those values then the thc has the torch bouncing up and down wildly. I have 25 in PID P, 0 in the other 2 PID fields and 0.1 in the height per volt field. If it were just one variable I would try changing it but with at least 4 to play with I could spend days trying to stumble on the correct combination.
I guess if I understood how they were used in calculating what the thc did I would have half a chance.
What settings does everyone else have in their run configs for thc and arc, it might at least give me a start in point
- phillc54
My guesses as a non cutter:I am not sure I am having the same problems as Rod. My issue is more that I don’t have the correct values in for the thc. I dont have any understanding of how they are used or where to start in working out some starting values.
Anti Dive should be around 90% - 95%
Void Sense is not working correctly so leave it off.
PID P is basically the reaction speed so probably start at 10 and work your way up.
PID's I & D probably leave at zero.
Height Per Volt only comes into play for on the fly height adjustment and the not working Void Sense. Approx 0.1 for metric or 0.004 for imperial.
- Dee436
Thanks for that Phil,
Makes it much easier, so for basic thc I just have PID P to play with.
- JTknives
- Thank you received: 32
I have kinda been hesitant to do an upgrade as I depend on this thing weekly and so do my customers. I had thought about picking up a second computer and trying a fresh install on that. I would think my install is so old that it would not be a simple update but rather a complete install with new Hal and ini files.
- Thank you received: 7488
This is the main reason why i love the 7i92, plug it and test the $/+ out of it, remove, plug on the machine and continue working.......well testing as i do not do much actual work with them.I have kinda been hesitant to do an upgrade as I depend on this thing weekly and so do my customers. I had thought about picking up a second computer and trying a fresh install on that. I would think my install is so old that it would not be a simple update but rather a complete install with new Hal and ini files.
- islander261
- Thank you received: 216
I have missed the last several upgrades so I am now waiting for the dust to settle.
I use a THC gain of 25 and a deadband of .1,others 0. If you are having problems with your THC start with the default deadband of 1. Double and triple check that your .ini and .hal lines for your Z axis are correct. I tried to get my THC to oscillate when I first tried PlasmaC and gave up when the worst I could do was a very "nervous" torch at truly ridiculous settings.
I always use a fixed THC set point (through much testing I know what it is on my system) to avoid cutting height errors caused by bad probing, very rare for me using PlasmaC. If you are worried about arc voltage changing with consumable wear track it with the statistics tab and adjust as needed with high mileage electrodes.
All puddle jump and kerf crossing (Void) values at 0.
The Height per volt range as stated is correct for HT and TD standard consumables. For those using HT Finecut consumables the value will be in the .00085" to .001" range, my usual for 2mm HR steel is .00095".
Velocity Hold values for most will be in the 85% to 90% range for good cuts. I am using 90% now and have only 1v or 2v voltage spikes at worst. I see this more often than most because I am rarely cutting rectilinear engineering work.
My 7I76E and THCad cards have been rock solid since first commissioning when you rule out operator errors.
- JTknives
