Another plasma component...
7 years 2 months ago - 7 years 2 months ago #143179 by phillc54
You need to add num_spindles to the "loadrt motmod" line.
In some cases it is "loadrt [EMCMOT]EMCMOT"
I did it this way:
num_spindles=[TRAJ]SPINDLES
Edit:
linuxcnc.org/docs/devel/html/man/man9/motion.9.html
Last edit: 7 years 2 months ago by phillc54. Reason: move quotes
7 years 2 months ago #143181 by rodw
phillc54 wrote: You need to add num_spindles to the "loadrt motmod" line.
I did it this way:
Edit:
Thanks, I have it working now...
That would have to be the obscurest documentation in the whole project!
The ini file docs for multi spindle really need attention. If I could not work it out, how would a new user get it working?
7 years 2 months ago #143202 by sevaz
Replied by sevaz on topic Another plasma component...
phillc54 wrote:
Maybe i updated too early, so has caught some bugs. So i just deleted plasmac_axis.py and everything started to work like it should.
I tried but couldn't simulate the behaviour you described. PlasmaC has no control over jogging, that is done by Axis.
But of course i lost all cool axis tweaks.
I am nor sure what you mean.
Ok, let me explain:
I set up a testing machine with a fresh new install of debian wheezy. Then I add wheezy repos(Master branch ) from buildbot.linuxcnc.org. After that I start Linuxcnc config picker from start menu.
Then i choose by machine > plasmac > metic axis;
Then i try to start it and get following error message
So I comment those lanes in both files:
In metric_plasmac_connections.hal
And in plasmac.hal
Only after that Axis starts and looks this way:
I installed debian on the old netbook, thus it has such a poor resolution, but the problem is the same on a working CNC.
So everything fine, except continuous jogging doesn't work at all. Neither keyboard nor screen buttons - and +, but if I set incremental jogging for example 10mm it moves. Then choose continuous again - nothing
So i decided that this problem is somehow connected with the axis tweaks, because default axis behaves normally.
That's why I deleted file plasmac_axis.py and restarted linuxcnc:
Now I have working continuous jogging, but there are no PlasmaC signals at the bottom anymore.
I would like to say, that i tried PlasmaC on my home PC with Ubuntu 18.04 and everything worked just right, except the first error message.
I think it could somehow depend on the old versions of Tk libraries, but unfortunately my knowledge in programming is limited.
I hope I've managed to clarify the problem, maybe I am just doing everything wrong, but PlasmaC on version 2.8 produced some good quality cuts without any serious problems.
7 years 2 months ago #143203 by phillc54
Thanks for the detailed report, I will try a new install following what you did tomorrow.
Have you tried a Debian Stretch install?
7 years 2 months ago #143207 by phillc54
When you say Wheezy do you mean the Wheezy ISO on the LinuxCNC website.
7 years 2 months ago #143209 by tommylight
Replied by tommylight on topic Another plasma component...
Just updated to build 498 of 2.9 and got infinite loops !
Metric PlasmaC sim
Uspace
Mint 19.1
Linux acer 4.16.12-rt5-kona-rt #1 SMP PREEMPT RT Fri Jun 8 10:39:47 JST 2018 x86_64 GNU/Linux
Guess yesterdays commit has not gone through yet.
Report attached, pin 'spindle.1.on' does not exist.
Time to create page: 0.432 seconds
