Another plasma component...
  • thefabricator03
  • Visitor
  • Visitor
7 years 3 weeks ago #147682 by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
John,
I think you are right about plasma spider,
I will go on there soon and see if I can convert any of the Mach3 cavemen to convert to LCNC.
7 years 3 weeks ago #147683 by rodw
islander261 wrote: +1 on this.
'03
You really need to cross post your experiences on PS, the folks there are sick of hearing from Rod and I about using LCNC.
Yes, there is one in particular who does not like the message I've delivered.... I'm sure the Islander and '03 know who I mean...
Do it Stefan!
The following user(s) said Thank You: Clive S, thefabricator03
  • thefabricator03
  • Visitor
  • Visitor
7 years 3 weeks ago #147684 by thefabricator03
One other thing I want to mention on here is how well the THC works.
After believing all the hype around CandCNC DTHC versions, I had version IV but they release version 5 soon after, I found it hard to believe that THC could be done cheaply but to a high standard. At the time a CandCNC DTHC IV was $500 USD for the card.
It just works, no two ways about it. I had problems with the CandCNC DTHC not working sometimes for no reason. That does not happen with the THCAD and PlasmaC.
I know I am preaching to the converted here but I do find it truly amazing how something so simple just works.
That is the reason I am working on developing LinuxCNC into a controller for my industrial robots. Once the development is done I will be able to cheaply monitor arc voltage while welding to track the positon of the weld seam keeping it on track. I priced the same system for one of my Motoman robots and it was $23,000AUD per robot.
Using LinuxCNC everyday on my plasma has confirmed its reliability if properly developed. I hope to one day have a open source config like Phills PlasmaC for industrial robots.
7 years 3 weeks ago #147686 by tommylight
Replied by tommylight on topic Another plasma component...
Thank you, all, for the info.
Due to exogenous circumstances i have not been able to test it on a machine, and i am reluctant to switch to it on client machines for two reasons, one is that the thc_toma config works perfectly and never ever fails so clients are very happy with it, and second it would require them to change the work flow. Also there is the issue of using SheetCam instead of Inkscape to get the full functionality out of PlasmaC.
In the words of Mr.Smith from "the Matrix", it is inevitable !!!
I am preparing parts and ordering stuff for 5 to 6 new plasma machines, from 1.1X0.6M to 6.5X2M with the fourth axis, it is terribly hard to get some parts here, and the worst part is i've spent the better part of last 3 months looking to outsource the metal work to some shops here and none of them are capable of making a straight, plum, correctly aligned metal construction. Lazy bastards !
My shop is to small at 80 sq.M. so it is already full, i can not extend it as soon it is going to be destroyed and new high rises built here, looking to find another place but nothing suitable so far, am completely broke from buying machine parts, have those said parts rusting and collecting dust in the shop, still waiting for some parts at that PET bottle factory, and i hate waiting, etc etc.
Still, i am healthy and so is my family, so frankly i do not give a rats a$$ about all that above, so in a moment of wisdom i am renting another shop thinking of opening a barber shop, of all things, so more running, less sleep, more challenges, more fun ! :)
7 years 4 days ago #148911 by KRAD-AT
Replied by KRAD-AT on topic Another plasma component...
Hello Guys!
Today I made a new Config and upgraded to plasmac.
Most of all seem to work perfect.
One thing I recognizes is that continuous jogging does not work. Jogging in increments works fine.
The same thing as user sevaz saw in the post below.
Is there a solution already?
Cheers Martin
sevaz wrote:
phillc54 wrote:
Maybe i updated too early, so has caught some bugs. So i just deleted plasmac_axis.py and everything started to work like it should.
I tried but couldn't simulate the behaviour you described. PlasmaC has no control over jogging, that is done by Axis.
But of course i lost all cool axis tweaks.
I am nor sure what you mean.
Ok, let me explain:
I set up a testing machine with a fresh new install of debian wheezy. Then I add wheezy repos(Master branch ) from buildbot.linuxcnc.org. After that I start Linuxcnc config picker from start menu.
Then i choose by machine > plasmac > metic axis;
Then i try to start it and get following error message
So I comment those lanes in both files:
In metric_plasmac_connections.hal
And in plasmac.hal
Only after that Axis starts and looks this way:
I installed debian on the old netbook, thus it has such a poor resolution, but the problem is the same on a working CNC.
So everything fine, except continuous jogging doesn't work at all. Neither keyboard nor screen buttons - and +, but if I set incremental jogging for example 10mm it moves. Then choose continuous again - nothing
So i decided that this problem is somehow connected with the axis tweaks, because default axis behaves normally.
That's why I deleted file plasmac_axis.py and restarted linuxcnc:
Now I have working continuous jogging, but there are no PlasmaC signals at the bottom anymore.
I would like to say, that i tried PlasmaC on my home PC with Ubuntu 18.04 and everything worked just right, except the first error message.
I think it could somehow depend on the old versions of Tk libraries, but unfortunately my knowledge in programming is limited.
I hope I've managed to clarify the problem, maybe I am just doing everything wrong, but PlasmaC on version 2.8 produced some good quality cuts without any serious problems.
7 years 4 days ago #148915 by grijalvap
Replied by grijalvap on topic Another plasma component...
Hi, I have some troubles to tune the PID loop basically I have a big steady-state error, I know every system is different, but do you have some guide or initial numbers?
thanks
Time to create page: 0.300 seconds
