Another plasma component...
7 years 3 weeks ago #147348 by tommylight
Replied by tommylight on topic Another plasma component...
Config attached in full, ziped to the max.
7 years 3 weeks ago - 7 years 3 weeks ago #147379 by phillc54
tommylight wrote: Config attached in full, ziped to the max.
Thanks Tom, I can see the tool change issue and hopefully I can push a fix today.
Any other issues?
Edit: A fix has been pushed for this issue.
Last edit: 7 years 3 weeks ago by phillc54.
7 years 3 weeks ago #147404 by phillc54
I have a fix for saving parameters so you don't need to press enter for entries done by keyboard. Before I push it I have a question.
I have explicitly prevented Kerf Width from being saved but I cannot remember why I did that.
Can anyone think of a reason for that or shall I allow it to be saved as well?
7 years 3 weeks ago #147406 by docwelch
Replied by docwelch on topic Another plasma component...
Was it so that it would always default to the material selected?
7 years 3 weeks ago #147417 by phillc54
docwelch wrote: Was it so that it would always default to the material selected?
Nope, I just had a play and it works OK if I allow it to save.
I must have thought I had a good reason at the time.:unsure:
7 years 3 weeks ago #147435 by tommylight
Things tend to get messy when running all that code through your head several times a day ! :)
The following user(s) said Thank You: phillc54, Clive S
Time to create page: 0.204 seconds
