- Thank you received: 2100
Another plasma component...
- phillc54
6 years 8 months ago #156840
by phillc54
Great, thanks Andreas.
I will push the fix tomorrow. In the meantime that file will need to be in any config that doesn't work.
- Backerman
6 years 8 months ago #157429
by Backerman
Replied by Backerman on topic Another plasma component...
Hi Phill!
I have another problem! Touch off button generates an error!
Thanks for the quick fix!
- phillc54
6 years 8 months ago - 6 years 8 months ago #157493
by phillc54
[strike]Does this happen for all axes?
Is it when touching off to Zero or to a specific value or both?
What locale do you use?[/strike]
It is something to do with locales, I can duplicate it here.
Last edit: 6 years 8 months ago by phillc54.
- phillc54
6 years 8 months ago #157502
by phillc54
OK, this is a combination of a couple of errors.
- I didn't allow locale translation for a couple of buttons
- There was an error in the recent German translation updates
The following user(s) said Thank You: Backerman
- Franklin
- Thank you received: 19
6 years 5 months ago #168579
by Franklin
Replied by Franklin on topic Another plasma component...
Hi, I have not updated the plasmac for a long time, and now after update the spotting does not work , plasmaŃ repeats attempts in one place and does not move to the next position.
There was already such error, I wrote about it on page 171 .
Before updating this worked fine.
Can you try my file on your machine?
Thanks.
Thanks.
- Uthayne
- Thank you received: 49
6 years 5 months ago #168581
by Uthayne
Replied by Uthayne on topic Another plasma component...
I had this same issue and it was fixed for me by using the Rev E plasmac sheetcam pp
Time to create page: 3.518 seconds
