New to all of this
16 Mar 2019 23:49 #128786 by rodw
Replied by rodw on topic New to all of this
....... you don't need master branch yet but may need to upgrade to master branch down the track to get access to the external offset branch for THC control.
There is the THC version that works with any branch of Linuxcnc, even the very old ones, and works with THCAD also, so having external offset branch is not a requirement for THC.
Yes, I did mention BigJohnT somewhere (well I hope I did!). So his config is here gnipsel.com/shop/plasma/plasma.xhtml
  • Moderator
  • Moderator
17 Mar 2019 00:36 #128788 by tommylight
Replied by tommylight on topic New to all of this
You have mentioned all of them in a thread somewhere lately, that is nice.
In this case it sounded like there is no other option except using external offsets branch for THC, but there are several.
17 Mar 2019 00:42 #128789 by rodw
I did mention them all in my first reply
Tommylight also has a good system that has recently been adapted to use Mesa and the THCAD instead of the Proma150 he uses in europe.
BigJohnT also has a config which was probably the original mesa config.
Islander261 has got a good robust working PID based system that he says easilly exceeds the performance of his previous commercial controller.
I've been using an experimental branch
  • Moderator
  • Moderator
17 Mar 2019 00:57 #128790 by tommylight
I knew you mentioned it somewhere ! :)
Just did not know it was on this thread. Sorry for the confusion caused.
  • JTknives
  • JTknives's Avatar Topic Author
  • Elite Member
  • Elite Member
17 Mar 2019 01:09 #128791 by JTknives
Replied by JTknives on topic New to all of this
So I ordered the j1900 brix and a stick of 4gb SO-DIMM DDR3L 1333 made by corsair. I then shot over to mesa website and went to order the THCAD10 as well as the 7i76e but the 7i76e is out of stock. It seams like most of there step/IO boards are out of stock. Is this normal and do thy get them back in stock quickly?
17 Mar 2019 01:47 #128793 by Leon82
Replied by Leon82 on topic New to all of this
They are building them now
17 Mar 2019 01:58 - 17 Mar 2019 02:09 #128794 by rodw
Also check BigJohnT's store for stock mesaus.com/index.php?route=common/home
I bought mine from there from Australia.
Last edit: 17 Mar 2019 02:09 by rodw.
  • JTknives
  • Elite Member
  • Elite Member
17 Mar 2019 20:46 #128852 by JTknives
he just messaged me back and thy are out 3 weeks. so i guess that will give me time to play around with linuxcnc and finish the table.
18 Mar 2019 12:39 #128888 by pl7i92
Replied by pl7i92 on topic New to all of this
New is relative as you say you got a mashine already you may be find yourself FAST in a Frontrow position
  • JTknives
  • Elite Member
  • Elite Member
20 Mar 2019 06:13 #129041 by JTknives
So the pc is being delivered tomarow. What version of Linux should I install?
Time to create page: 0.202 seconds
