New to all of this
- Thank you received: 4648
21 Mar 2019 17:39 #129203
Replied by andypugh on topic New to all of this
Off-the-wall suggestion: Is this a
"fake" USB stick?
There are some out there that claim to be bigger than they are. Everything seems to work, but files written outside he real size simply can't be read back
- JTknives
- Thank you received: 32
21 Mar 2019 18:00 #129205
by JTknives
Replied by JTknives on topic New to all of this
im not sure on the usb. I got it from office max I think. I will try another one that has a light on it.
- JTknives
21 Mar 2019 18:12 #129208
by JTknives
Hot damn it working. I got another usb stick and tryied the 32bit iso and it worked.
- JTknives
21 Mar 2019 22:19 #129225
by JTknives
When I get home I’m going to try and do the same thing with the 64bit.
Thanks guys for all your help
- Thank you received: 4141
22 Mar 2019 12:58 #129252
Replied by rodw on topic New to all of this
I'm not saying anything (but 12 posts ago I did)
Onwards and upwards
Onwards and upwards
- JTknives
22 Mar 2019 14:10 #129258
by JTknives
That’s what god me to try a diffrent thumb drive. Thank you
The following user(s) said Thank You: RotarySMP, rodw
- JTknives
23 Mar 2019 17:06 #129380
by JTknives
Any tips on what needs to be done to reduce latency. I think I had seen somewhere that some of the cores need to be locked down to stabilize it. but i could not figure out how to do it. I turned off boost in the bios but things go worse. and tips? thanks guys
- Leon82
- Thank you received: 79
23 Mar 2019 17:22 #129381
by Leon82
Replied by Leon82 on topic New to all of this
Check the bios cool and quiet and hard disk monitor I turned off.
24 Mar 2019 02:16 #129426
There is some earlier info about using ISOLCPUS but this is obsolete for the J1900 hardware. Just go into the BIOS and keep turning stuff off and rechecking. Don't use the included Wifi. Grab a USB dongle instead.
Remember you won't have a base thread with mesa hardware so latency is much relaxed. I think mine is up around 120000. So long since I checked. also, there is a way to call the latency test from the command line and only test the servo thread. Maybe someone will remember for you!
- Thank you received: 7465
24 Mar 2019 19:33 #129510
Replied by tommylight on topic New to all of this
latency-histogram --nobase
Time to create page: 0.551 seconds
