Configuring Plasmac - a complete THC/plasma config for any hardware
12 May 2019 07:14 #133513 by phillc54
Comment out these lines in your machine hal:
line 233:
net spindle-enable        =>  pid.s.enable
line 244:
net spindle-enable             <=  spindle.0.on
Cheers, Phill.
12 May 2019 07:36 #133521 by JTknives
Oh thank the lord, phill you are a god send. I am up and running and no errors. Thankyou all for all your help in this journey out of this black hole.
12 May 2019 07:38 #133522 by phillc54
You are welcome.
Now you have a bit of fine tuning to do...
Cheers, Phill.
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 May 2019 07:56 #133526 by rodw
great. Think on the bright side. I've been in the hole for about 3 years.....
My wife talked about me workon on my spaceship in the garage as she had no idea what I was doing so that where my machine name came from...
15 May 2019 02:23 #133801 by AgentWD40
I have a suggestion, or maybe a tip, that some may find convenient. Make a launcher (shortcut) to the plasmac linuxcnc installation so you don't have to fumble with the terminal each time.
Save the following in a file called PlasmaC.desktop on your desktop:
[Desktop Entry]
Version=1.0
Type=Application
Comment=Start LinuxCNC PlasmaC Configuration
Exec=/home/{YOUR USERNAME HERE}/plasmac/scripts/rip-environment linuxcnc '/home/{YOUR USERNAME HERE}/linuxcnc/configs/plasmac/{YOUR INI FILENAME HERE}.ini'
Icon=linuxcncicon
Terminal=false
StartupNotify=false
Name=PlasmaC
OR
Modify an existing configuration shortcut's Exec line to look like the one above.
Might need to mark it executable. From the terminal that's
chmod 755 ~/Desktop/PlasmaC.desktop
The following user(s) said Thank You: phillc54, rodw
15 May 2019 19:50 #133893 by JTknives
When I set up mine I just check the box titled create desktop link when you run LinuxCNC from a terminal.
Oh how are you guys connecting your Estop. I looked through the hal and noticed an Estop command but no pin call outs.
15 May 2019 22:07 #133926 by AgentWD40
*face palm* I just figured that would try to launch the 'other' installation of linuxcnc instead of the rip-environment. I figured wrong. Whoops.
  • rodw
  • Platinum Member
  • Platinum Member
16 May 2019 07:43 - 16 May 2019 07:43 #133952 by rodw
The secret is to use estop-latch
BigJohnT has an example here forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
I ended up with 3 estops buttons and I managed to create an estop chain in hal for all of them by extending this but there were no examples anywhere
Last edit: 16 May 2019 07:43 by rodw.
16 May 2019 20:36 #134003 by JTknives
thanks, i got it working. i figured it would not be a good idea to fire it up without an estop.
i also tied in the stepper drive fault back into the board. Took a bit of trial and error but i got it with this. I tried originally to use axis instead of joint as i found reference to doing it that way but i could never get it to work. am i doing this correctly or am i off base?
# ---Axis fault ---
net axis.x.fault <= hm2_7i76e.0.7i76.0.0.input-13
net axis.y.fault <= hm2_7i76e.0.7i76.0.0.input-14
net axis.z.fault <= hm2_7i76e.0.7i76.0.0.input-15
net axis.x.fault => joint.0.amp-fault-in
net axis.y.fault => joint.1.amp-fault-in
net axis.z.fault => joint.2.amp-fault-in
  • rodw
  • Platinum Member
  • Platinum Member
16 May 2019 20:44 - 16 May 2019 20:45 #134005 by rodw
MIne's a bit more complex
# --- ESTOP CHAIN STARTS ---
net latch-reset <= iocontrol.0.user-request-enable
net latch-ok-in <= iocontrol.0.user-enable-out
net latch-ok-in => estop-latch.0.ok-in
net latch0-out <= estop-latch.0.ok-out
net latch0-out => estop-latch.1.ok-in
net latch1-out <= estop-latch.1.ok-out
net latch1-out  => estop-latch.2.ok-in
net latch2-out <= estop-latch.2.ok-out
net latch2-out => estop-latch.3.ok-in
#net latch3-out <= estop-latch.3.ok-out
#net latch3-out => estop-latch.2.ok-in
net latch-reset => estop-latch.0.reset
net latch-reset => estop-latch.1.reset
net latch-reset => estop-latch.2.reset
net latch-reset => estop-latch.3.reset
net latch-out iocontrol.0.emc-enable-in <= estop-latch.3.ok-out
net estop-out estop-latch.3.fault-out
# --- EXTERNAL ESTOP SWITCH - CONTROL BOX---
net external-estop <= hm2_7i76e.0.7i76.0.0.input-00
net external-estop => estop-latch.0.fault-in
# --- EXTERNAL ESTOP SWITCH - CONSOLE ---
net console-estop <= hm2_7i76e.0.7i76.0.0.input-31-not
net console-estop  => estop-latch.3.fault-in
# --- PENDANT ESTOP SWITCH ---
net pendant-estop <=  hm2_7i76e.0.7i76.0.0.input-26-not
net pendant-estop => estop-latch.1.fault-in
# --- TORCH BREAKAWAY E-STOP ---
net torch-breakaway <= hm2_7i76e.0.7i76.0.0.input-06
net torch-breakaway => estop-latch.2.fault-in
# --- E-STOP STEPPER DRIVE DISABLE ---
net estop-out hm2_7i76e.0.7i76.0.0.output-05
I think I'd like to take the breakaway out of this chain and just make it pause the machine.
Last edit: 16 May 2019 20:45 by rodw.
Time to create page: 0.181 seconds
