- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Configuring Plasmac - a complete THC/plasma config for any hardware
- islander261
- Thank you received: 216
16 May 2019 15:55 #134006
by islander261
Replied by islander261 on topic Configuring Plasmac - a complete THC/plasma config for any hardware
Rod
If you have connected it correctly the Plasmac branch will handle torch break away well with the plasmac component. I have lots of experience with it now! I actually haven't lost a part since starting to use Plasmac. You do actually want it to pause and not put the machine into estop if you don't use Plasmac.
- phillc54
- Thank you received: 2100
17 May 2019 04:23 #134039
by phillc54
Replied by phillc54 on topic Configuring Plasmac - a complete THC/plasma config for any hardware
Rod,
I have written a configurator to create a plasmac config. I have posted it in the Another plasma component and you may want to link to it in the first post.
Cheers, Phill.
Cheers, Phill.
The following user(s) said Thank You: billykid, tommylight
- billykid
- Thank you received: 83
20 May 2019 11:38 #134374
by billykid
Replied by billykid on topic Configuring Plasmac - a complete THC/plasma config for any hardware
first of all thanks to those who are doing this good job.
I'm doing the first tests with a 7i80 + 7i30 + thcad 0-10, the motors work and the voltage is read .. I would like to know how to use this thcad mode 0 or 1? I also have the arc-ok signal that I used with an analog thc.
Thanks in advance
mauro
Thanks in advance
mauro
- Thank you received: 4154
20 May 2019 16:28 - 20 May 2019 16:29 #134399
Replied by rodw on topic Configuring Plasmac - a complete THC/plasma config for any hardware
The THCAD mode select (W1) should be down to select unipolar mode. This gives you a 0-10v range not -5v to +5v
You should also select the divider link to 1/32 and adjust your full scale frequency and offset accordingly (eg divide the calibration spec by 32)
Last edit: 20 May 2019 16:29 by rodw.
- billykid
21 May 2019 01:56 - 21 May 2019 02:06 #134451
by billykid
thank you Rod, but I was referring to the 0 - 1 - 2 mode of plasmac .. in practice with or without an external arc-ok signal
edit
sorry i just saw a page 2 that you say use mode 1
edit
Last edit: 21 May 2019 02:06 by billykid.
- Thank you received: 7504
22 May 2019 21:11 #134646
Replied by tommylight on topic Configuring Plasmac - a complete THC/plasma config for any hardware
Yup that should be it, although you have the possibility of having ArcOK generated from linuxcnc.
- billykid
23 May 2019 05:14 #134682
by billykid
thank you ,
anyway they advised me to use mode 1 with thcad and since I already have the sensor I did so
- phoenix
11 Jul 2019 03:07 #139082
by phoenix
Replied by phoenix on topic Configuring Plasmac - a complete THC/plasma config for any hardware
I want reverse run where can i get it
- phillc54
11 Jul 2019 03:09 #139083
by phillc54
Why do you insist on multiple posts for the same question, it is really annoying...
- snugglylovemuffin
- Thank you received: 11
13 Jul 2019 17:00 #139268
by snugglylovemuffin
Replied by snugglylovemuffin on topic Configuring Plasmac - a complete THC/plasma config for any hardware
I'm trying to clone this but she doesn't chooch.
github.com/phillc54/linuxcnc-plasmac/
Do you have an updated Git link?
- CNC Machines
- Plasma & Laser
Time to create page: 0.150 seconds
