Rebuilding Plasma CNC
6 years 7 months ago #161478 by Nizsten
Hello, Friends!
I am working on getting an old Plasma CNC machine rebuilt.
We have removed the old control box, and we are beginning to look into repurposing the old motors.
We are looking into building a computer for the LinuxCNC environment, but I have a hard time determining the best way to connect Linux CNC to the motors on the old Plasma machine.
All of the motors (for the X, Y, and Z-axis) connect and splice into one connection.
In addition, this is the connection to the actual plasma.
I'm looking for opinions on the best way to connect a LinuxCNC computer to these two connections.
Thanks!
6 years 7 months ago #161479 by rodw
Replied by rodw on topic Rebuilding Plasma CNC
No eBay APP ID and/or Cert ID defined in Kunena configurationThe first connector looks like a 20 pin ATX connector used on computer power supplies.
The second looks like an audio 6 pin DIN connector which should be easy to find too.
au.element14.com/pro-signal/psg01567/cha...ni-din-ns/dp/1280671
If you need further help we'd need more info about the motors but I am assuming most likely they are stepper motors in the absence of more info.
The following user(s) said Thank You: Nizsten
6 years 7 months ago #161480 by Nizsten
Replied by Nizsten on topic Rebuilding Plasma CNC
That sounds right.
Would I need any hardware to connect to those? Any special boards, or would being able to connect to the computer be enough?
6 years 7 months ago #161481 by tommylight
Replied by tommylight on topic Rebuilding Plasma CNC
We would need much more pictures and info to be able to help, like:
Where do the wires from each connector go and to what are they attached on the other side
Where is the existing electronics, if there are any
etc
etc
6 years 7 months ago #161486 by rodw
I think we need a lot more info about your motors, motor controllers and plasma cutter, if it has a voltage divider before advising.
If it is stepper motors, you can start with one or two parallel port breakout boards (depending on inputs required) and a Mesa THCAD to read torch voltage. But you would get higher performance from a Mesa 7i96 or 7i76e ethernet board.
Some photos of motors and controllers would help. Do some of those wires go to home and limit switches?
You may like to read this linuxcnc.org/docs/devel/html/plasma/plasma-cnc-primer.html
6 years 7 months ago #161494 by Nizsten
We have currently removed all of the electronic components.
The controller we had would not respond to any form of input.
These are the pictures that I have for the motors and limits.
Each axis has limits, as I understand it.
I have looked at some boards that have been suggested in the forums.
Most of the drawings I have seen have ATX ports for each axis/motor.
With all of the wiring for these motors going to one 20-pin ATX connections, would we need to rewire them to work with boards with the motors' connections separated?
Time to create page: 0.119 seconds
