- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Plasma made in a barn as cheap as possible :) and it's not going smooth
- Thank you received: 4114
Well everyone is wiser after the event, it is a pity it took almost 18 months for this to show up. I certainly don't remember anyone complaining about the upper limit until recently.
Yeh, I think its only come to a head becasue people are pushing the envelope with HF start machines instead of blowback torches.
The HF machines must be much more erratic with torch voltage. But allowing it to be set to 9999 should have solved the issue
Sorry I never thought to look at it earlier but it stood out immediately when I saw Fred's post.
I am hoping the arc voltage blows the cobwebs out of the system so it reports a clean voltage signal without significant variations. If it doesn't, I think the work done inside the plasma need to be reviewed.
- jay1st
- Thank you received: 17
- jay1st
I still have around 15v on the nozzle, but now it's firing up in mode 0
Did 2 things :
_set the upper limit to 300 (maxed out) and lower to 50
_opened the cutter, again, and connected right after the 2 big chokes and i had a bunch of various MOV on hand so i changed those on the torch/ground connections to a lower voltage while testing the cutter, and found-out that a 250v MOV works perfectly.
After all that the ARC OK signal based on the THCAD voltage is good, fires 100% of the time.
Now i need to find a table to help me out with the various voltages depending on the thickness for the THC control and the tool table.
BTW do i need to fiddle around with the PID / GAIN section of the configuration panel ( i did and it's all messed up i guess) ?? and still waiting on some larger metal sheets to adjust off of it.
- jay1st
Rod, problem solved
There are no shortcuts here, in the absence of manufacturer's cut charts, you need to do test cuts. Pick a height, write a gcode file that cuts a few lines about 6 inches long at different speeds. Pick the cleanest cut with the best angularity, use that height and then repeat the same process with that speed at different heights. Then you might need to repeat with a finer resolution between cuts.I suspect this might be a bit fiddly with Plasmac as it does not allow z axis code so you might have to write a materials file for each different option and change the material between cuts from the gcode.
- jay1st
- Thank you received: 7440
And the IGBT are on the primary side so might not be isolated from the mains.
- phillc54
- Thank you received: 2100
All you need to do is use the default material (i.e. don't select a meterial in the gcode) and you can change any of the parameters in the Run Panel. If you type a value in then you DO need to press "Return".I suspect this might be a bit fiddly with Plasmac as it does not allow z axis code so you might have to write a materials file for each different option and change the material between cuts from the gcode.
- jay1st
Could i use a Hyperthem table with speeds and rates depending on thickness as a base to start with ?
- CNC Machines
- Plasma & Laser
