- Thank you received: 4153
Tumbler Build - For cleaning plasma cut parts.
- thefabricator03
- Visitor
Do you have any tip on setting up my VFD?
Seriously though other than the fact I have one sitting here I have never used one. I have a mate who lives in my street who is a bit of an expert on them. But the wiring is simple but there is a bit in the programming. He typically uses the existing knob as a speed control but you can use an external one. Sing out if you need help, I might be able to enlist his help...
- thefabricator03
- Visitor
rodw wrote: I have a tip for you. Its called a VFD (Variable Frequency Drive) :laugh: :laugh: :laugh:
Thanks Rod,
I have been reading the manual and it looks pretty straight forward. I was thinking about using an industrial potentiometer for speed control as it has a input for one.
The only thing I am not really sure of is how to work my E-stops into the wiring. When they are pressed I want to shut down power to the motor instantly. I will do some more reading but the VFD has 5 digital inputs I can use for E-stop control but I am not sure how to cut power from the motor without turning power off to the VFD.
Would it be as simple as wiring a Contactor in between the motor and VFD? And controlling the contactor with the VFD relay output? I am thinking I still need a way to stop the power in case the VFD malfunctions.
- thefabricator03
- Visitor
Since you mentioned it I went back and checked my spelling, I have been spelling it VDF for some unknown reason. Makes me paranoid now about what else I have been misspelling
- Thank you received: 7491
What type ?thefabricator03 wrote: Tom,
Do you have any tip on setting up my VDF?
I do have 2 of them here collecting dust, as luck would have it, yesterday i was reading the manual for the Dinverter one (3X380-480V, 2.2KW) and it can do RS485 AND RS422 !!! Nice, will have to mess more with it later on.
Some general tips:
Since it is going to be moving heavy stuff, set the spin up delay to 1 or 2 seconds, and spin down to 2 or 3 seconds.
Try to keep it around 50 or 60 Hz as normal motors will not like faster rotation and will eventually wear the bearings.
Some new VFD's have an Auto Tuning feature, use it if you can, it can greatly improve efficiency, hence less heat and strain on the motor.
Worm gear is the best choice for use in this case as it does not allow the constantly changing load to impact the motor, making it slip while rotating.
Get a simple adjustable timer, so you do not have to wait for it to finish, thank me later.
Almost all VFD's have inputs for a motor thermistor, find one and strap it to the motor, in case something gets stuck inside of the tumbler causing more load, it will save the motor from going up in smoke.
I do have some of the those thermal fuses here, they are made to be attached to the relay directly and and can save the motor if any of the phases get loaded more than it should. They are all adjustable as to the current they will trip.
