My Newb Plasma Table Attempted Build
- phillc54
- Thank you received: 2100
02 Jun 2020 19:20 #169890
by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
It seems to be in one direction.
Just move to a random X/Y point then move only Y+ and measure the move then move Y- and measure the move.
The following user(s) said Thank You: dvn4life1972
- Thank you received: 4155
02 Jun 2020 19:22 #169891
Replied by rodw on topic My Newb Plasma Table Attempted Build
If you are missing steps and there is nothing mechanical binding, then the acceleration profile might be too aggressive which is why I suggested halving it.
Can you list voltages used, drivers, amps set in driver and motors?
- dvn4life1972
- Thank you received: 173
02 Jun 2020 19:43 #169892
by dvn4life1972
Ah yeah man I remember you recommending that Rod...got sidetracked with the wife and when I came back to work on the issue I totally brain-farted. Is that in the main hal file?
The drivers are KL-5056, motors are NEMA 23 570oz/in 3.5A, power supply for those is a Meanwell SE 600-48, I have the drivers set to 2.7A (I didn't want to run them at max...didn't see a need with low-loading on a plasma table aluminum gantry) and microstepping is 1/4.
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
- Thank you received: 7506
02 Jun 2020 19:48 #169893
Replied by tommylight on topic My Newb Plasma Table Attempted Build
In the ini file, max_acceleration, for each axis.Is that in the main hal file?
- dvn4life1972
02 Jun 2020 20:03 #169895
by dvn4life1972
Just did this and Y+ is exactly as programmed (2"), and Y- back from where it stopped in the first move is exactly 1/32" short...which is consistent with what's been happening on the squares I've been cutting to troubleshoot with.
Well the gcode seems to be correct. Looks a lot like backlash or lost steps in the Y axis.
Run the Y axis back and foward and measure the results
I've been re-resquaring the gantry. Between adjustments I run the gantry and Z to the opposite corner of the table at 900ipm, then back to home and measure from the end of the rail to the gantry plates on both sides of the Y. It returns to the exact same position every single time. Wtf am I missing here lol.
- phillc54
02 Jun 2020 20:08 #169896
by phillc54
If you grab hold of it when it is stopped can you physically move it that much?
- dvn4life1972
02 Jun 2020 20:11 #169897
by dvn4life1972
These were set at 30.0. I changed them to half (15.0) and all of the joints I changed are doing some crazy stuff, like turning hard enough to slip the belts and grind. Not good (they're all super tight too).
02 Jun 2020 20:14 #169898
Can you also change the step time and step space in the ini file to 10000, do some test, and report back the results ?
Thank you.
Thank you.
- dvn4life1972
02 Jun 2020 20:17 #169899
by dvn4life1972
I'll have to run it again and then when it gets there try it, and I'll also reset the stuff Tommy asked about so I'm doing 2 for 1
02 Jun 2020 20:25 #169900
post your ini file too so we can check you made the right changes..
The following user(s) said Thank You: tommylight, dvn4life1972
Time to create page: 0.184 seconds
