My Newb Plasma Table Attempted Build
- Thank you received: 7506
03 Jun 2020 09:56 #169946
Replied by tommylight on topic My Newb Plasma Table Attempted Build
I did ask if you are getting such errors, the reply was no.
Set the base thread to 100000.
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
- Thank you received: 173
03 Jun 2020 10:18 #169950
by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
I recall that, I did mention I got sidetracked yesterday...I apologize.
- Thank you received: 5337
03 Jun 2020 10:20 #169951
Replied by PCW on topic My Newb Plasma Table Attempted Build
Its a 7I96 configuration so no base thread
Setting the servo thread to 2000000 might help (though laptops are not suggested in general)
In your hal file I would remove all statements like:
setp pid.x.maxerror .0005
and in your ini file I would set all ferror limits smaller
Currently they are:
FERROR = 0.5
MIN_FERROR = 0.05
which will mask fairly major setup issues with step generation
I would set them (all axis) to
FERROR = 0.01
MIN_FERROR = 0.001
In addition since you have a high latency host PC I would add
# latch stepgen feedpack position 200 usec before nominal read time:
setp hm2_7i96.0.dpll.01.timer-us -200
setp hm2_7i96.0.stepgen.timer-number 1
To your hal file
Currently they are:
FERROR = 0.5
MIN_FERROR = 0.05
FERROR = 0.01
MIN_FERROR = 0.001
To your hal file
- dvn4life1972
03 Jun 2020 11:31 #169960
by dvn4life1972
Does it matter where in the hal file, or is there a preferred part of it to insert this? I'm not ashamed to admit I'm super ignorant.
To your hal file
03 Jun 2020 12:15 #169966
No, it does not matter where that's placed.
( though I tend to put global settings at the top of the file )
The only thing in hal files that is sensitive to order (AFAIK)
is the order of addf statements and loadrt statements where
one module depends on the other.
- dvn4life1972
03 Jun 2020 13:50 #169972
by dvn4life1972
I made all of those changes and it homes just fine. Then when I attempt to jog I immediately get a joint 1 and joint 2 following error.
03 Jun 2020 13:57 - 03 Jun 2020 13:58 #169974
Actually that's a good thing. it shows that the stepgen is not following the commanded position.
This usually means a setup error of some kind or a severe latency issue on the host PC.
If you made significant changes in the hal/ini files (in velocity or acceleration settings)
can you repost them?
Last edit: 03 Jun 2020 13:58 by PCW.
- dvn4life1972
03 Jun 2020 14:04 #169975
by dvn4life1972
I reverted everything back to how it was after it went crazy trying to change them yesterday. They're the same as the ones I shared with you (attaching here again for convenience).
03 Jun 2020 14:14 - 03 Jun 2020 14:16 #169976
The per axis velocity and acceleration limits are higher than the stepgen velocity and
acceleration limits, This is the likely cause of the following errors. I would double the stepgen
velocity and acceleration limits and see if that fixes the errors.
Last edit: 03 Jun 2020 14:16 by PCW.
03 Jun 2020 14:19 #169978
Also set the steplen and stepspace to at least 5000, preferably 10000 until you have everything in working order.
Time to create page: 0.403 seconds
