My Newb Plasma Table Attempted Build
03 Jun 2020 19:38 #170054 by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
Idk what else to try. This seems really weird to me. And yes the preview looked perfect. So does the parts I've tried to cut.
  • Moderator
  • Moderator
03 Jun 2020 19:39 #170055 by tommylight
Replied by tommylight on topic My Newb Plasma Table Attempted Build
I missed that Tom. It is good in previews here on sims as well, and it should as it is only a simple bit of code.
Baffling...
Also checked the sim on 3 PC's, all good.
Unfortunately, just yesterday it got to my brain that he was using the wizard, despite him mentioning that several times and was going to put that code here for him to try, but was testing some stuff so got sidetracked, and today forgot about it till Mike mentioned it, so thank you Mike_Eitel.
Also unfortunately i have no usable compressor that can do more than 5 seconds of cutting and no usable table ATM, so i could not test that. @##@$#@^!$^!%!@$%!@^%%#!@$!^@!
03 Jun 2020 20:10 #170056 by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
It also works fine on master.
Now I'm lost...
It is strange that it displays ok on your preview but doesn't track correctly on your machine. Did you try a pen plot with a new wizard code that doesn't have kerf width compensation?
03 Jun 2020 20:33 #170057 by dvn4life1972
I get the same issue with and without kerf width compensation on.
03 Jun 2020 20:42 #170058 by phillc54
How about without leadin and leadout
03 Jun 2020 20:58 #170059 by dvn4life1972
I didn't try without lead in/out. But it does this on parts too (other than wizard-generated).
03 Jun 2020 21:15 #170060 by phillc54
Sorry, I thought it was only wizards, I am off on a tangent again...
So it is almost like slipping a tooth on a direction change. Is that an axis with one motor or two?
The following user(s) said Thank You: dvn4life1972
03 Jun 2020 21:19 - 03 Jun 2020 21:22 #170061 by dvn4life1972
Y axis, 2 motors. Definitely not slipping a tooth. And cutting perfectly a 2in square using basic gcode that Tommy suggested.
Edit: but it is acting as-if it's slipping a tooth or something, just in the Y- direction.
Last edit: 03 Jun 2020 21:22 by dvn4life1972.
03 Jun 2020 21:24 #170062 by phillc54
That was what made me think it was wizards only. So the square you cut with Toms code is square on all corners and all sides have the correct dimensions.
03 Jun 2020 21:41 #170063 by dvn4life1972
That's correct. As if the waters weren't muddy enough on this already...
Time to create page: 0.137 seconds
