My Newb Plasma Table Attempted Build
- phillc54
- Thank you received: 2100
03 Jun 2020 21:50 #170064
by phillc54
Replied by phillc54 on topic My Newb Plasma Table Attempted Build
It sure is strange. I guess you probably should download a fresh copy of LinuxCNC to at least discount the software side of things. At least if it shows up with a pen then you don't need to waste cuts. If you download then make master and it still plays up it may be worthwhile changing to 2.8 branch and recompiling and see if there is any difference. Not much help I know but I am out of ideas.That's correct. As if the waters weren't muddy enough on this already...
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
- Thank you received: 173
03 Jun 2020 21:57 #170065
by dvn4life1972
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
Well, it's nobody's fault my stuff decided to go all weird. I'm half-Irish, maybe that's it. I'm going to wipe that PC (saving my config files) and go again and see tomorrow.
- phillc54
03 Jun 2020 22:27 #170067
by phillc54
OK, good luck.
- Mike_Eitel
- Thank you received: 183
04 Jun 2020 00:49 #170072
by Mike_Eitel
Replied by Mike_Eitel on topic My Newb Plasma Table Attempted Build
Good morning. Nice to read that you are one step further.
1. Pos What is in your tool table. Can you clean that. Can you clean the. var file.
2. Pos I believe external offset is used in plasma. Is there some offset at start?
I think it is time that you zip your complete dir including actul var etc. So the others can trow that to their testmachines. You have some rubish parameter somewhere.
- dvn4life1972
04 Jun 2020 14:02 #170119
by dvn4life1972
I don't think there is an offset at start, although I'm a fabricator and am only just beginning to learn anything about this software (understatement) so somebody else can probably better answer your question #2.
Attached my configs directory zip. I'm getting ready to wipe the PC and start fresh on it...I haven't been looking forward to this process though.
- dvn4life1972
04 Jun 2020 17:18 #170150
by dvn4life1972
Did all the software stuff and the problem still exists. I removed the lead in/out from the wizard just to see what it might do, it reduced the error by half. Almost not detectable by the eye but there nevertheless. I have no idea what to do now other than to go to mach3, which I really don't want to do...but I have to get up and running somehow.
- Thank you received: 5337
04 Jun 2020 17:24 #170153
Replied by PCW on topic My Newb Plasma Table Attempted Build
Does the backplot show the error?
Have you tried swapping X and Y drives?
- dvn4life1972
04 Jun 2020 17:31 #170154
by dvn4life1972
No. I'll try it, but I have doubts because of the perfect cut with the simple code Tommy provided. I'll report back shortly.
- dvn4life1972
04 Jun 2020 17:36 #170156
by dvn4life1972
By this do you mean the display?
04 Jun 2020 17:46 #170160
Yes
Time to create page: 0.385 seconds
