My Newb Plasma Table Attempted Build
- dvn4life1972
- Thank you received: 173
04 Jun 2020 17:54 #170162
by dvn4life1972
No, the part shows as it should be. Also I swapped drivers, and can't home...I get following errors. Swapped them back around and now I can't do anything. More following errors when trying to home. Sometimes one axis will make it through, then another will have the error. I'm about sick of this.
Replied by dvn4life1972 on topic My Newb Plasma Table Attempted Build
Yes
- dvn4life1972
04 Jun 2020 18:07 #170164
by dvn4life1972
Gonna end this thread here. I'm just going to tear it down and get rid of the belt drive, the laptop, etc etc and do a big do-over now. I should've never taken in those jobs at the time I took them. This really blows my mind.
- Thank you received: 5337
04 Jun 2020 18:21 #170169
Replied by PCW on topic My Newb Plasma Table Attempted Build
Swapping drives should have no effect on the software
Did you just unplug the step/dir and motor connectors from the
drives and swap drives?
- Thank you received: 7506
04 Jun 2020 18:23 #170170
Replied by tommylight on topic My Newb Plasma Table Attempted Build
What the h.......
Did you try to do a round shape, not from the wizard, use inkscape, draw a circle, path>object to path, extensions>gcodetools>path to gcode, open in LinuxCNC.
What the h.......
The following user(s) said Thank You: dvn4life1972
- dvn4life1972
04 Jun 2020 18:29 #170173
by dvn4life1972
I powered down everything and swapped the plugs (both plugs per each driver). Even after I put them back - they're labeled - it was giving errors.
- dvn4life1972
04 Jun 2020 18:30 #170174
by dvn4life1972
No, I don't have Inkscape. I'm getting a regular PC and starting over with that. I only need the G.D. thing to cut my plates for rack and pinion and then it can go all the way to hell.
What the h.......
04 Jun 2020 18:42 #170176
Can you try this, it is in MM and has G21 in it so it should work as is, feed set at 10inch/m
G21 (All units in mm)
F250
G00 X50.000000 Y25.000000
M3 S1
G02 X48.096988 Y15.432914 I-25.000000 J0.000000
G02 X42.677670 Y7.322330 I-23.096988 J9.567086
G02 X34.567086 Y1.903012 I-17.677670 J17.677670
G02 X25.000000 Y0.000000 I-9.567086 J23.096988
G02 X15.432914 Y1.903012 I0.000000 J25.000000
G02 X7.322330 Y7.322330 I9.567086 J23.096988
G02 X1.903012 Y15.432914 I17.677670 J17.677670
G02 X0.000000 Y25.000000 I23.096988 J9.567086
G02 X1.903012 Y34.567086 I25.000000 J-0.000000
G02 X7.322330 Y42.677670 I23.096988 J-9.567086
G02 X15.432914 Y48.096988 I17.677670 J-17.677670
G02 X25.000000 Y50.000000 I9.567086 J-23.096988
G02 X34.567086 Y48.096988 I-0.000000 J-25.000000
G02 X42.677670 Y42.677670 I-9.567086 J-23.096988
G02 X48.096988 Y34.567086 I-17.677670 J-17.677670
G02 X50.000000 Y25.000000 I-23.096988 J-9.567086
G01 X50.000000 Y25.000000
M5
G00 X0.0000 Y0.0000
- dvn4life1972
04 Jun 2020 18:49 - 04 Jun 2020 18:50 #170179
by dvn4life1972
I can't. It won't even home now.
Edit: just gives following errors. And not on the same axis each time. Maybe my laptop got a virus.
% G21 (All units in mm) F250 G00 X50.000000 Y25.000000 M3 S1 G02 X48.096988 Y15.432914 I-25.000000 J0.000000 G02 X42.677670 Y7.322330 I-23.096988 J9.567086 G02 X34.567086 Y1.903012 I-17.677670 J17.677670 G02 X25.000000 Y0.000000 I-9.567086 J23.096988 G02 X15.432914 Y1.903012 I0.000000 J25.000000 G02 X7.322330 Y7.322330 I9.567086 J23.096988 G02 X1.903012 Y15.432914 I17.677670 J17.677670 G02 X0.000000 Y25.000000 I23.096988 J9.567086 G02 X1.903012 Y34.567086 I25.000000 J-0.000000 G02 X7.322330 Y42.677670 I23.096988 J-9.567086 G02 X15.432914 Y48.096988 I17.677670 J-17.677670 G02 X25.000000 Y50.000000 I9.567086 J-23.096988 G02 X34.567086 Y48.096988 I-0.000000 J-25.000000 G02 X42.677670 Y42.677670 I-9.567086 J-23.096988 G02 X48.096988 Y34.567086 I-17.677670 J-17.677670 G02 X50.000000 Y25.000000 I-23.096988 J-9.567086 G01 X50.000000 Y25.000000 M5 G00 X0.0000 Y0.0000 %
Last edit: 04 Jun 2020 18:50 by dvn4life1972.
04 Jun 2020 19:04 #170181
You could widen the following error limits, but this is just a work-around for host PC latency issues.
I suspect your laptop does not have the good real time performance the LinuxCNC requires.
You may be able to work around this by
1. Setting the servo thread time to 2 mS (2000000)
2. Widening the following error limits to say 0.005, .02
- dvn4life1972
04 Jun 2020 19:15 #170184
by dvn4life1972
I'm already with ya on that, in a way. Picking up a proper PC for the task tomorrow. The servo thread time is already at 2000000.
Time to create page: 0.249 seconds
