How to cut thick material from edge
- alexandrub
- Thank you received: 5
12 May 2020 22:10 #167570
by alexandrub
How to cut thick material from edge was created by alexandrub
hello,
I ask how can i cut 20mm with an powermax 45 xp? I need to start the cutting from material outside. I tried in different mode but i did not succeeded becsuse the arc ok condition is not met. Finally i start the cutting with material piercing but is not ok for the torch. So how can i start the cutting from outside?
Thank you.
Thank you.
- Thank you received: 4151
12 May 2020 22:45 #167573
Replied by rodw on topic How to cut thick material from edge
I don't think you will be able to. I use 120 amps on 16mm so I doubt that you'll get the 45 to do the job at all. PLus if you did get it to work, the duty cycle will kick in and it will stop cutting anyway.
Check the specs in your manual and then talk to your Hypertherm Rep about an upgrade. I'd say you'd need 85 amps minimum
12 May 2020 22:47 #167574
ONe rule of thumb I was told was to use 10 amps per mm. That is a bit over but you get what I'm saying
- thefabricator03
- Visitor
12 May 2020 23:44 - 12 May 2020 23:45 #167575
by thefabricator03
Replied by thefabricator03 on topic How to cut thick material from edge
I echo Rods statement,
I cut a bit of 25mm plate ,
And 20mm plate,
I have a Powermax 125, and on the thicker stuff it still struggles. It will do it easily enough but its not the same as cutting say 8mm. I really need a 200 amp unit for cutting the thicker stuff. I dont do it all day everyday tho so the 125 is not over stressed.
Attachment not found
And 20mm plate,
Last edit: 12 May 2020 23:45 by thefabricator03.
12 May 2020 23:59 #167577
Oops, I was not game to say 125 amps cos there goes another $3-5k
- thefabricator03
- Visitor
13 May 2020 00:02 #167579
by thefabricator03
Yeah they dont miss you. But the MAXPRO200 retails for $23k AUD, not chump change!
13 May 2020 01:59 #167595
Now you are talking. HF start so a few extra considerations there
- thefabricator03
- Visitor
13 May 2020 02:22 #167601
by thefabricator03
Yeah but I am sure the extra effort to set it up would be worth it. Just for the extra consumable life alone.
- alexandrub
13 May 2020 04:01 #167603
by alexandrub
Replied by alexandrub on topic How to cut thick material from edge
13 May 2020 07:59 #167618
Yeh, we knew what you meant. I had to find your manual. I am surprised they list edge start for material that thick but the proof is in the pudding
Time to create page: 0.131 seconds
