How to cut thick material from edge
- thefabricator03
- Visitor
15 May 2020 23:57 #167910
by thefabricator03
Yeah I am the same. I have always been curious with the CNC Oxys, with how they work with their nozzles. I know from my own experience when you do not get a nice straight oxy flame because of a dirty nozzle that cut quality goes to shit fast.
Maybe they have a special kind of nozzle. I will look into it when I get time.
Replied by thefabricator03 on topic How to cut thick material from edge
I've never done it on a machine, always by hand. I would angle the torch head and wash the molten material away for piercing thick material.
- Thank you received: 7488
16 May 2020 09:54 - 16 May 2020 09:54 #167941
The older one had nozzles about 6cm long, so plenty of room to direct the flow, the new one had less than 3cm.
IIRC, i cut it at 400mm/m as i was scared to push it faster. Chikin !
Replied by tommylight on topic How to cut thick material from edge
Very slow, but that depends on the torch a lot. The one i used to cut that piece was and older machine torch, weight over 5KG, also had a new one at about 1.2KG, so huge difference just in weight.How fast do Oxy machines move Tom? I would imagine very slowly, also how do they go with piercing?
Last edit: 16 May 2020 09:54 by tommylight. Reason: typo
The following user(s) said Thank You: rodw, thefabricator03
Time to create page: 0.182 seconds
