Esab Ultrarex UXD-P2000 Upgrade Project
- Esaber
- Thank you received: 16
19 Jul 2020 18:06 #175173
by Esaber
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
The 4 wires coming from the collision/sensing probes go to the box behind the y motor.
Are we keeping this box?
- Thank you received: 7480
19 Jul 2020 18:16 #175175
Replied by tommylight on topic Esab Ultrarex UXD-P2000 Upgrade Project
The Z limits are easy, they are written on the connector, so check if the LLIM and ULIM are also going to the computer board.
For the collision/probe sensors, see if you can find the + and - powering them, the outputs are easy to manage. Also check if those go to the computer board.
If none of them go to the control box/computer board, routing new shielded cables should be easy enough.
My machine had none of them going to the control box, they just ended in the Z axis box, and from there they went on as RS232 communication, so i just added the new cables.
19 Jul 2020 18:17 #175176
Yes, the drive for the Y axis servo motor is there.Are we keeping this box?
- Esaber
19 Jul 2020 18:28 - 19 Jul 2020 18:40 #175178
by Esaber
Last edit: 19 Jul 2020 18:40 by Esaber.
- Esaber
19 Jul 2020 18:32 #175179
by Esaber
They all go through the box which is behind the Y motor then to the control box. But we don't know how they are mapped when leaving the small control box.
19 Jul 2020 18:46 #175181
Again, from the beginning, we are keeping all the boxes, only the control box/computer box will be empty, and only the Z axis motor goes out.
It seems easier to add new wiring for those sensors/switches. Although i would give it a go at finding out if they go all the way to the computer box by using a long wire to extend the DVM cable.
- Esaber
19 Jul 2020 18:50 - 19 Jul 2020 18:59 #175183
by Esaber
If I'm following you this z-axis box will be removed. wires will be routed directly from all sensors/probes to the control box. My friend is telling me this small box behind the Y motor (not the board of the y motor encoder) is connected to the hypertherm.
Now the sensing/collision wires are 16 in total and they all go through a small board which is on the head mount then they go out in 4 wires to the z-axis box. Do we wire these wires from this small box (4 shielded wires to the linuxcnc box) or do we wire each sensor separately to the linuxcnc box (16 wires) and thus get rid of the small board?
Last edit: 19 Jul 2020 18:59 by Esaber.
- Esaber
19 Jul 2020 18:57 #175184
by Esaber
We were replying at the same time
Ok We keep all but the control box and the z motor.
I'll let you read my previous message about sensing/collision wires
What do you make of the pneumatic up/down wires? are we keeping them?
19 Jul 2020 21:32 #175204
We will try to make it work with the 4 wires, so leave the box as is.Do we wire these wires from this small box (4 shielded wires to the linuxcnc box) or do we wire each sensor separately to the linuxcnc box (16 wires) and thus get rid of the small board?
19 Jul 2020 21:34 #175205
Leave them as they are, mark them as you might need them later to add a pneumatic drill. Very useful as LinuxCNC can control many spindles/drills/torches....
I would add wiring for those also.
I did.
Time to create page: 0.335 seconds
