Esab Ultrarex UXD-P2000 Upgrade Project
25 Jun 2020 12:54 - 25 Jun 2020 12:54 #172723 by Esaber
Replied by Esaber on topic Esab Ultrarex UXD-P2000 Upgrade Project
OK. Thanks !
Be back soon :-)
Last edit: 25 Jun 2020 12:54 by Esaber.
25 Jun 2020 22:38 #172760 by Esaber
Esab UltraRex UXD-P2000 schematic PDF file is here. 65 MB.
mega.nz/file/LOZhlYRC#OWgoSdOFC5wtZODOiu...28t6j1ivzvJ6OFFyQxNY
27 Jun 2020 15:54 #172863 by Esaber
Question: How does the esab floating head sensor deal with irregularities on the object being cut? Can it handle such object or you need a laser like sensor in this scenario to measure/process height distance?
27 Jun 2020 16:29 #172865 by tommylight
Replied by tommylight on topic Esab Ultrarex UXD-P2000 Upgrade Project
Answer:
It does not, it just finds the top of material, the "material following" is done by the THCAD and the software by measuring the plasma cutter voltage.
Checked the schematics last night, it seems to have only 2 servo motors, so less wires.
27 Jun 2020 16:38 #172868 by Esaber
Ok. Will that be any different with the small plasma cutter we are going to wire? I mean is the voltage measurement standard on all plasma cutters or is it only the case with what came with the machine or with some, ie the hypertherm?
27 Jun 2020 16:51 #172872 by tommylight
All of them use external THC electronics in conjunction with the floating head to follow the material. We like to use the THCAD as it is very cheap, extremely good quality, works perfectly and is fully integrated into PlasmaC configuration for LinuxCNC so you get full control of the machine on screen.
Nothing differs, we agreed to use THCAD from the beginning, and two small 1MOhm resistors. :)
Hypertherms usually have a dedicated output for that, so there is no need for the two resistors.
27 Jun 2020 16:59 #172876 by Esaber
Ok good :-)
My friend is hunting for the wires. Some of the wires go to the power box then to the control box. We are thinking about putting the mini-atx box and all the cards in this same powerbox as there is enough space to hold all the components there. We can then add just a screen keyboard mouse cables from the power box to the esab control box where we will install the screen.
This will allow us to remove the extra wiring going from this box to the esab control box.
Is this a good idea?
27 Jun 2020 17:06 #172879 by tommylight
No wires go to the power box, everything should be installed in the control box.
The only wires that go from control box to the Z axis are 4 motor wires and floating switch wires.
27 Jun 2020 17:17 #172880 by Esaber
So those are only power wires.
This is the box:
27 Jun 2020 17:19 - 27 Jun 2020 17:20 #172881 by Esaber
Another pic:
Last edit: 27 Jun 2020 17:20 by Esaber.
The following user(s) said Thank You: arvidb
Time to create page: 1.203 seconds
