Distance Traveled Per Motor Revolution
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
31 Aug 2020 14:04 - 31 Aug 2020 14:06 #180163 by snowgoer540
Distance Traveled Per Motor Revolution was created by snowgoer540
Forgive me if this is covered in another thread I couldn't find...
I currently have a direct drive R&P system on my X and Y axis'. The D.P. of the spur gear is .75", which makes my distance traveled per revolution ≈2.37" (≈59.8mm).
I didn't know about the plasma primer before I built my table :blush:, but now that I do, and I see the issues associated with resonance and cutting around curves, etc. I want to add a reduction system. I know that the Plasma Primer says:
Stepper motors suffer from resonance and a direct drive pinion is likely to mean that the motor is operating under unfavourable conditions. Ideally, for plasma machines a distance of around 15-25mm per motor revolution is considered ideal but even around 30mm per revolutions is still acceptable. A 5mm pitch ball screw with a 3:1 or 5:1 reduction drive is ideal for the Z axis.
My questions are as follows:
  1. Where did these numbers come from?
  2. Realistically, all of those numbers are possible. 2:1 would put me at 30mm, 3:1 would put me at 20mm per rev, 4:1 would put me right at 15mm. Is there really a huge difference between 15mm and 20mm? Where should I shoot to land realistically
  3. I know that reduction is going to slow down my rapids. One reason I wonder all of this is because it would seem that the number would really be driven by max RPM of the stepper, and it would also seem that the resonance would be different for different steppers, but maybe that's incorrect?
  4. I think this is the last one... What does this do for acceleration? I think I read somewhere that ideal acceleration for Plasma would be 50 in/sec^2 (or maybe that's 50 in/min^2?)... When you reduce the axis, does that cut the acceleration by the same amount? In a 3:1 reduction system, would I have to set my acceleration to 150 in order to get the desired 50?
I think that's it for now. If you think of anything I didn't think of, I'd be happy to learn more!
Last edit: 31 Aug 2020 14:06 by snowgoer540.
31 Aug 2020 14:17 #180164 by tommylight
Replied by tommylight on topic Distance Traveled Per Motor Revolution
I'll put all of that in a single question:
What do you want to cut with it?
  • snowgoer540
  • Moderator
  • Moderator
31 Aug 2020 14:37 #180168 by snowgoer540
Replied by snowgoer540 on topic Distance Traveled Per Motor Revolution
I'll answer that with: Yes.
Everything and anything that comes my way. Signs, brackets, round holes, etc. The real answer is no matter what it is, I want a quality cut.
31 Aug 2020 15:07 #180175 by tommylight
That is easy, you just need one of these : :) :) :)
If you do not mind, have a go through this topic, it will help you get an idea of what it takes to build a machine that can cut anything you throw at it:
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
Or you can do one with two floating heads, each with full functionality, so one can do plasma and the other one can do Oxy/Acetylene up to 160mm :
forum.linuxcnc.org/show-your-stuff/35337...2m-work-area-or-12x7
Then you might want to do one of these, as you said you want to do anything :
forum.linuxcnc.org/show-your-stuff/37784...-or-any-hard-surface
  • snowgoer540
  • Moderator
  • Moderator
31 Aug 2020 16:08 - 31 Aug 2020 16:28 #180184 by snowgoer540
I will read through those when I get home from work later! Thanks Tommy.
Just to be clear, the machine is built. It already has a direct drive, I'm looking to reduce it because I see the waviness caused by the resonance. Just looking to plan my attack and design constraints before I get too far down the rabbit hole.
That table you built is really nice by the way :)
Last edit: 31 Aug 2020 16:28 by snowgoer540.
31 Aug 2020 17:53 #180197 by tommylight
The first link has everything, even the reduction so you might get some ideas.
31 Aug 2020 20:28 #180220 by rodw
Replied by rodw on topic Distance Traveled Per Motor Revolution
1. It was me! (complete with typo referring to the Z) as I wrote it. And Tommy cos he taught me forum.linuxcnc.org/30-cnc-machines/31509...-loaded-pinion-drive Plus Tom Caudle from Candcnc who often mentioned 1" per rev. You can see from the link I made the same mistake as you but fixed it before I built my table (Thanks Tom!). I settled on 3:1 and 30mm/rev becasue thats what I had in my shed!
2. Its actually a lot more complex to be able to make a recommendation. Everything about steppers is predictable. You could try this approach www.machinedesign.com/motors-drives/arti...rs-for-linear-motion but I think it has some bugs in the maths. With a complex model we found the two key parameters were reduction drive and pinion diameter. You can't really lump them together into a distance per rev. And yes, even resonance RPM can be predicted.
3. Yes its quite a balancing act between rapids and designing for maximum cut speed. (We used 10240 mm/min) based on one manufacturer's cut charts. Basically I designed for our cut speed but then looked at the torque chart for a given stepper to see if it had enough left in the tank to hit our target rapids. say 30 m/min (at least 25 m/min). There is a high probability your motor selection is wrong (cos we could not find many motors that hit our target performance)
4. The model cited does not really work on target acceleration, but on an acceleration profile. But the time taken to get to speed sets the acceleration.... More reduction give more torque to overcome inertia so acelleration gets better with bigger reductions.
so 1 G = 9.81 m/sec/sec. Jim Colt from Hypertherm often mentions 0.3 G as a target but when I reviewed high end machines, they were doing up to 0.5G to 0.7G. We settled on a target of 0.5 G (Roughly 5 m/sec/sec) becasue we did not want to be just mediocre. So with a 3:1 reduction, we exceeded the model and achieved 8 m/sec/sec. (0.8G) But with a 5:1 reduction (different motors), we could not get past 5 m/sec/sec 0.5G. Rapids we settled on 36 m/min.
But this was with high end stepper motors and high end stepper drivers (Tommy's beloved Lams) and a 64 volt AC power supply (about 90 volts to the motors). All in all about an AUD $3k upgrade.
Send me a message here www.vmn.com.au/contact-us and If I get your motor specs and axis weights, I might be able to advise further. Sorry but I can't share the model here due to an NDA.
The following user(s) said Thank You: tommylight, snowgoer540
31 Aug 2020 20:43 #180225 by tommylight
@Rod,
I always thought you are much better than me at explaining things, and this proves my point exactly.
Thank you. :)
The following user(s) said Thank You: rodw, snowgoer540
  • snowgoer540
  • Moderator
  • Moderator
31 Aug 2020 23:54 #180246 by snowgoer540
Wow, awesome, thank you Rod!
I had actually sent you a message to that contact us before, I might have to send you a PM on PlasmaSpider. I do know the motor specs, but I don't know that I know my axis weights :blush: I could probably ballpark it with CAD if I assign material properties. Would save me from taking it apart and weighing it bit by bit lol.. Otherwise I'd just post my email address here, but I'm not sure if the rules allow it. Maybe not the smartest thing.
Shame that I might end up having to buy pinions too.
01 Sep 2020 10:44 #180303 by rodw
Sorry, I do remember seeing the email but when I go looking its gone into the ether. Yes you will get me on the spider or the zone. The last few months have been quite crazy for me. This Covid-19 is meant to be causing a recession but thats not what we are seeing... I don't think you will need to change pinions.
Time to create page: 0.187 seconds
