- Thank you received: 106
Would you mind sharing?rodw wrote: Looks fantastic. Can't wait to see how it works.I was given a DXF file for a 8" blast gate yesterday. I'm still pondering how to put mine together. How much space do you have from the bottom of the slats to the bottom of the tray?
That's a good question. You are likely to have your exhaust table running before me, I still have to get LinuxCNC to move the gantry around! I went ahead and removed the electronics and computer that I had been using. Hopefully that will force me to get this one running with LinuxCNC. I got some motors turning on the bench, but that is not the same.rodw wrote: Should the air rams be covered to protect from falling sparks do you think?
txtrone wrote:
rodw wrote: I read through your thread (on another forum) where you documented the entire spaceship build. You are a madman, but you have a really cool spaceship!
That thread on plasmaspider is an impostor! (Well just a summary of my build)
The real thread is here on this forum forum.linuxcnc.org/show-your-stuff/32029...cutter-build?start=0
All 69 pages of it. Man I have to bust through that number its kinda suggestive!
Its been a long journey, my Spaceship!
This madman is kinda time poor right now so there is no guarantee the spaceship will fly on a cushion of air before yours does!
I found this pic
See: safe-welding.com/extraction-table-7-fact...cted-during-cutting/
I kinda like how there are no sliding shutters to get stuck and how the air ram uses the hatch it opens to shield itself against sparks. I think I might use a dual rod air ram if I go this way.
