Downdraft design questions
5 years 6 months ago #206848 by txtrone
Replied by txtrone on topic Downdraft design questions
Thanks!
3 years 2 weeks ago #282833 by mab
Replied by mab on topic Downdraft design questions
Hi, I realize this is an old thread, but I'd like to know if this was a success or not? Is it working? Worth the effort?
Thanks,
Mike
3 years 2 weeks ago #282834 by txtrone
Thanks,
Mike
The actuation setup that Rod programmed for me worked great. The exhaust port on that table was not large enough to stay up with the smoke though. What I would suggest doing is to setup at least 4 exhaust ports coming off the side of your table. Then connect those four ports to the main exhaust duct on the outside of the table. That will allow you to move a lot more air AND you will be able to install your 'blast gates' on the outside of the table. At least that is what I am going to do when I cut it back over to plasma work. Good luck!
3 years 2 weeks ago #282844 by mab
Thanks for the update!
Time to create page: 0.360 seconds
