Downdraft design questions
  • thefabricator03
  • New Member
  • New Member
5 years 9 months ago #194317 by thefabricator03
Replied by thefabricator03 on topic Downdraft design questions
-not is used to invert a pin, say you had a limit switch you wanted to be normally open and its wired normally closed, you would put -not at the end of the text in the HAL for that switch to invert it.
5 years 9 months ago #194318 by txtrone
Replied by txtrone on topic Downdraft design questions
thefabricator03 wrote: -not is used to invert a pin, say you had a limit switch you wanted to be normally open and its wired normally closed, you would put -not at the end of the text in the HAL for that switch to invert it.
That's simple enough, thanks!
5 years 9 months ago #194319 by rodw
Replied by rodw on topic Downdraft design questions
Be sure to use Halshow a lot to see the signals and the pin names as you build this out.
5 years 9 months ago #194338 by Clive S
Replied by Clive S on topic Downdraft design questions
Can I use a sensor for an axis home AND positive limit? I did not have limits on my old table, only home switches... so I am not familiar with exactly how limits work.
Yes. linuxcnc.org/docs/2.8/html/config/ini-homing.html
The following user(s) said Thank You: txtrone
5 years 9 months ago #194427 by txtrone
rodw wrote: Very cool. Thanks for sharing. We await the next one with smokey burning rags.... or even better a torch arc!
This video shows a 90 second duration, 600 CU FT, smoke emitter. I am unsure how well this simulates the actual smoke from cutting steel plate, but... I do know this... if you forget to connect the compressed air line to the solenoid manifold before this test, your shop will fill up with this smoke. :whistle:
5 years 9 months ago #194438 by tommylight
Looks very good towards the beginning of the table, but a bit less towards the end.
Either way, it seems to have more than enough flow to suck the ..... smoke nicely ! :)
Time to create page: 0.351 seconds
