Downdraft design questions
5 years 10 months ago #193342 by txtrone
Replied by txtrone on topic Downdraft design questions
rodw wrote: I think you said you already have the downdraft component set up so kepe it in that file. Check how I did it in the Sim I shared earlier. You could put it in your main hal file. don't forget to loadrt and addf the component too.
I followed your instructions in order to get the sim going, it works great. I am just a bit lost trying to cut that over to my 'live' version.
I need to do some more reading on HAL.
5 years 10 months ago #193354 by rodw
Replied by rodw on topic Downdraft design questions
Sorry, been busy today.
Can you attach your hal and ini files?
Also, can you list the pins on the 7i76e you wish to use for your solenoids?
5 years 10 months ago #193366 by txtrone
rodw wrote: Can you attach your hal and ini files?
Sure thing, I will be at the shop later today and I will post the files. Right now I have the solenoids connected to output pins 17 - 24 on TB6.
5 years 10 months ago #193373 by txtrone
rodw wrote: Sorry, been busy today.
Pins 17 - 24 on TB6.
Attached are my hal and ini files
File Name: my_LinuxCN...hine.hal
File Size:10.49 KB
File Name: my_LinuxCN...hine.ini
File Size:4.46 KB
5 years 10 months ago - 5 years 10 months ago #193384 by rodw
So install a decent text editor, from the command line
sudo apt-get install geany
So now from the instructions in the original post
forum.linuxcnc.org/plasma-laser/40517-do...ions?start=10#188738
Copy the file ddraft4x2.hal from into your config folder.
Now open your ini file in geany and locate the [HAL] section and add the new file to it
[HAL] HALUI = halui HALFILE = my_LinuxCNC_machine.hal HALFILE = ddraft4x2.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal
Save the ini file
So now Linuxcnc will know to open our extra ddraft4x2.hal file.
From the 7i76e manual, you have used Output 0 to Output 7 so copy the following lines into our new file.
net zone0 <= ddraft4x2.0.trigger-0 net zone0 => hm2_7i76e.0.7i76.0.0.output-00 net zone1 <= ddraft4x2.0.trigger-1 net zone1 => hm2_7i76e.0.7i76.0.0.output-01 net zone2 <= ddraft4x2.0.trigger-2 net zone2 => hm2_7i76e.0.7i76.0.0.output-02 net zone3 <= ddraft4x2.0.trigger-3 net zone3 => hm2_7i76e.0.7i76.0.0.output-03 net zone4 <= ddraft4x2.0.trigger-4 net zone4 => hm2_7i76e.0.7i76.0.0.output-04 net zone5 <= ddraft4x2.0.trigger-5 net zone5 => hm2_7i76e.0.7i76.0.0.output-05 net zone6 <= ddraft4x2.0.trigger-6 net zone6 => hm2_7i76e.0.7i76.0.0.output-06 net zone7 <= ddraft4x2.0.trigger-7 net zone7 => hm2_7i76e.0.7i76.0.0.output-07
Save the file and from the command prompt run linuxcnc by typing would you believe
linuxcnc
if there are any errors, note them. I am assuming you have already compiled and installed the component
It is possible there are some typos above. To guard against this, you may like to check the pin nema in halshow before you make these changes
If for any reason you change your ini file, you will just need to add that line back in.
From where you are now, I would add your limit switched by hand. Part of the job is already done for you in your main ini file where you will find blocks like this:
# ---setup home / limit switch signals--- net x-home-sw => joint.0.home-sw-in net x-neg-limit => joint.0.neg-lim-sw-in net x-pos-limit => joint.0.pos-lim-sw-in
Before these lines, probably where it says
# external input signals
you just need to define these signals
net x-home-sw <= hm2_7i76e.0.7i76.0.0.input-12-not net x-neg-limit <= hm2_7i76e.0.7i76.0.0.input-13 net x-pos-limit <= hm2_7i76e.0.7i76.0.0.input-20-not
This is where its important to check everything with halshow to know if you need to use the -not signal and everything is working as expected when you trigger a physical input
Last edit: 5 years 10 months ago by rodw.
The following user(s) said Thank You: txtrone
5 years 10 months ago #193395 by txtrone
rodw wrote: So now...
Huge thanks rodw! I will get down to the shop tomorrow and report back on how it goes. :)
Time to create page: 0.411 seconds
