Downdraft design questions
5 years 10 months ago #193130 by txtrone
Replied by txtrone on topic Downdraft design questions
Thanks for holding my hand through that!
Do I have the diode polarity correct at the solenoid?
5 years 10 months ago #193132 by Aciera
Replied by Aciera on topic Downdraft design questions
Yes diode is fine like that.
The following user(s) said Thank You: txtrone
5 years 10 months ago #193133 by txtrone
Aciera wrote: Yes diode is fine like that.
Thanks again! Hopefully I can get the blast gates working over the holidays.
5 years 10 months ago #193199 by txtrone
This is how I have the diodes wired across the solenoid terminals. Does this look correct? I did not connect the 'drain' wire to the solenoid, but I will connect it to a common bus, which will be connected to the cabinet ground.
5 years 10 months ago #193208 by txtrone
Sanity check before I go live.
This is the 7i76e, powered by 24v, attached to eight solenoids via digital outputs, with a diode across the terminals at each solenoid. I used two negative terminal blocks in the schematic to make this easier to look at. I am only using one in the cabinet.
5 years 10 months ago #193211 by rodw
Replied by rodw on topic Downdraft design questions
From what I can see, you should be good to go.
Wire in the power and check you have 5 volts on a stepgen (eg between TB2-1 and TB2-6)
I think I would get the motion side up and running if you have not already.
Then I would install the ddraft component and connect the outputs to them in hal.
Check with halshow its working like in the screen dump I shared.
Check with a multimeter that the pin goes high +24V (between the output pin and GND - TB1-8) in sync with Halshow.
So when you get that far you know all is good on the 7i76e side
So then power off the 7i76e and connect one solenoid to one output pin. Power up again and confirm that shutter fires in that segment.
Once happy, wire up the remaining solenoids and watch on with big grin while making music with jog wheel and air rams!
Time to create page: 0.117 seconds
