- Thank you received: 5334
Sorry PCW, did not notice that in the other topic, or this one or ...PCW wrote: Nothing should connect to TB1 pin 5 (VIN)
VFIELD (TB1 pins 1..4) is where +24V power goes
Did it look out of whack to you? I have been looking back and forth between Norbert's drawing and mine and it looks the same. I feel like I'm tripping.rodw wrote: I'll leave others confuse you about the power connection.
Ok, so I am making this harder than it needs to be... I do that quite often. Would you mind posting a link or part number to exactly what you are referring to, 'discrete component'? Thxrodw wrote: If you used a discrete diode, you would just bridge the solenoid connectors using the diode with the solid band pointing back towards the output.
