- Thank you received: 106
txtrone wrote: Ah, that makes sense! I may be able to rearrange them.
2. Avoid stacking heat producing components one above the other, and allow an unrestricted flow of air behind components whenever possible
7. Wiring can also affect enclosure temperature. Properly cabling wires and routing bundles along enclosure corners keeps wires from resting on components and helps minimize airflow restriction.
