Downdraft design questions
5 years 10 months ago - 5 years 10 months ago #191987 by Himarc3D
Replied by Himarc3D on topic Downdraft design questions
Whats the 2 black box near your power supplies?
Your idea for the solenoids board are nice
Last edit: 5 years 10 months ago by Himarc3D.
5 years 10 months ago #191995 by txtrone
Replied by txtrone on topic Downdraft design questions
Himarc3D wrote: Whats the 2 black box near your power supplies?
The black boxes are power filters. Link
I wish I could take the credit, this is rodw's idea.
5 years 10 months ago #191996 by txtrone
tommylight wrote: BTW you do not have enough hobies on that table ! :)
heh ... I think the guys over at the tube amp forum needed a break from me anyways.
I did not get as far a long today as I had hoped. I had a real case of the Mondays...
5 years 10 months ago #191997 by rodw
Replied by rodw on topic Downdraft design questions
But heck, I only envisaged one of them. 16 amps should be heaps. Are you using 3 phase power? That would make sense.
5 years 10 months ago #192004 by txtrone
rodw wrote: But heck, I only envisaged one of them. 16 amps should be heaps. Are you using 3 phase power? That would make sense.
Yeah, that is probably overkill. I assumed I should connect these power filters to incoming mains and then out to the Meanwell AC/DC converters... but now I wonder if I should put these power filters after the converters and run the DC power through them.
Yes, we have 120/208 wye.
5 years 10 months ago #192007 by rodw
I just used one of these so it protected everything. Mesa hardware, stepper drivers and all.
www.jaycar.com.au/iec-emi-power-line-fil...G1_vowhoCzc0QAvD_BwE
I found some noise was entering the control box via the mains ground wire but this killed it.
Bearing in mind I am no electronics expert but I think:
It would only make sense to use 3 if you were using 3 phases and spreading the load across those phases. This is how Lam Technologies suggest how you set up their drives (if using 3 phase).
I think you'll have to build two more machines now!
The following user(s) said Thank You: txtrone
Time to create page: 0.387 seconds
