Downdraft design questions
5 years 10 months ago #192062 by Himarc3D
Replied by Himarc3D on topic Downdraft design questions
I cant see the difference between vertical and horizontal using passive coling or with heatsink drivers if you haver proper space between the drivers to air flow.
In my mind the question is how hot they get to install whatever the position just pay attention to the heatsink side and proper space to air flow
My motors i follow the manufacture instructions i dont runt it over 80C (68C).
Some drivers are din mount so you cant install horizontal or some models have fan and you need to pay attention to air flow direction.
I have yasukawa sigma driver (servo) and its up mounting and i think its because have fan up side.
I dont know the driver spec here but i guess its the same the oriental about orientation and looks like he have 40mm to 50mm between the driver
www.orientalmotor.com/products/pdfs/opmanuals/HM-60128-7E.pdf
www.orientalmotor.com/products/pdfs/Step...ionBIntro_B2-B42.pdf .
5 years 10 months ago #192590 by txtrone
Replied by txtrone on topic Downdraft design questions
I decided to rearrange the driver boards now.
The following user(s) said Thank You: chimeno, tommylight, rodw, Aciera, Coachbuilder
5 years 10 months ago #192601 by tommylight
Neat ! :)
The following user(s) said Thank You: txtrone
5 years 10 months ago #192679 by txtrone
tommylight wrote: Neat ! :)
Thanks! I just got the motors moving! I need to land the home switches and do some calibration... then I will have to 'hit the books' on Plasmac.
I will clean up the wiring a bit more after I get everything working.
I am not sure exactly when I should integrate the pneumatic actuator solenoids, should that be done before I get into Plasmac, or after?
5 years 10 months ago #192684 by tommylight
Motor wires seem very thin, that will limit the torque and speed by quite a margin.
4X0.75 is the absolute minimum for small Nema17 motors that i use, for anything bigger i use 4x2.5mm2.
5 years 10 months ago #192688 by txtrone
tommylight wrote: Motor wires seem very thin, that will limit the torque and speed by quite a margin.
Interesting. These motors came prewired from the vendor of my previous electronics package. I just checked, these motors are wired with 18AWG, you would use 14AWG? What wire type/make do you use? Thx
Time to create page: 0.264 seconds
